Viscous Fans
mudlva
Viscous Fans
Post by mudlva »
Hi all
how do you check your viscous fan to see if it is working properly??
my mates nissan s fan has never roared at all including when climbing the kopu the whitianga hill in the middle of the summers day. gauge was reading hot but then everything was hot as well.
it turns freely when the motor is cold
any ideas :?: :?:
tweake
Re: Viscous Fans
Post by tweake »
i'm a bit rusty but when cold it should turn a little bit. it shouldn't be free and spin around. probably needs repack with silicone.
SV1K
Site Admin
Re: Viscous Fans
Post by SV1K »
tweake wrote:probably needs repack with silicone.
I have never heard of silicone being used to repace them??? Are you sure?
I know that you can buy viscous fan oil from BnT, just take it apart then add the oil and put back together, cheaper than buying a new one at $500 :shock:
8)
tweake
Re: Viscous Fans
Post by tweake »
the oil is silicone grease. the surf forum as good instructions on repacking them and toyota part numbers for the "oil".
UBZ
Re: Viscous Fans
Post by UBZ »
yeah , the toyota silicone grease is about $44 for 10ml, you need about 28mls for a standard fan.
DaveM
Re: Viscous Fans
Post by DaveM »
You can get new aftermarket viscous hubs for under $200 for the Safari's
mattscruiser
Re: Viscous Fans
Post by mattscruiser »
my one on the 80 died all the wax came out of it so it was a quick fix as i needed it for towing so i unbolted it and filled it up with car bog now it draws bulk air theres no mucking around
p.s have since replaced
rangimotors
Re: Viscous Fans
Post by rangimotors »
mattscruiser wrote:my one on the 80 died all the wax came out of it so it was a quick fix as i needed it for towing so i unbolted it and filled it up with car bog now it draws bulk air theres no mucking around
Ba ha ha ha, I was waiting for you to post on this!
p.s I have a wof now so keen for a few more trips and a few less fines.
I always run electric fans these days so I can turn them off in mud of deep water or they just flick shit everywhere or end up going through your radiator and putting a big ass hole in there.
Return to “Tool Shed”
