Optimists mount winch in the front
front of car is pointing where you want to go, correct ?
Pessemists mount winch at the rear
if i get stuck it will be better to go backwards same way ?
Realists do not have a winch. Tree is always a bit to far anyway.
the real truth about winches
my 4wd is not a truck
Re: the real truth about winches
definatly an Optimist
optimist here too
was a realist then I brought a longer rope
What do we call those with a hand winch....covering all bases. I am the optimist with the hand winch for back-up.
Al
Al
Guess I'm in 2 minds as mine goes forwards and backwards and is mounted in the middle
rokhound wrote:Guess I'm in 2 minds as mine goes forwards and backwards and is mounted in the middle
Thats so you can get the best angle to get it back on its wheels after you flop it!!!!!
I'm none of the above as my winch is sitting in a box waiting to be fitted when I finally get my arse into gear and finish the new toy.
albundy wrote:What do we call those with a hand winch....covering all bases. I am the optimist with the hand winch for back-up.
Al
Careful!
After market front and rear bumper with a welded box section in the middle and a lock pin. This way u can mount the winch on a removable mounting plate with the corrosponding box section and fit it to the front or rear and pin it in place with a power plug on both ends, works like a charm.
redz driver
I'm both,
fitted two one to go forward and when all else fails one to pull me back
Real men drive swb leaf spring trucks
