Boost Guage Install
For all Nissan related topics
FORGE1
Boost Guage Install
Post by FORGE1 »
Hey guys,
Just wanting to know where would be the best place to install a boost guage. I have had a look in the engine bay and nothing has really jumped out to me.
Any help out be great.
Thanks Everyone
badnuz
Re: Boost Guage Install
Post by badnuz »
i would suggest not putting the boost gauge under the bonnet :roll:
on the steering colum maybe?
DaveM
Post by DaveM »
Do you mean mounting the guage, or how to "plumb" it up?
nzhunter
Post by nzhunter »
also if someone could let me know which vaccuum lines i need to tap into for my battery voltage gauge that would be great
FORGE1
Post by FORGE1 »
badnuz wrote:i would suggest not putting the boost gauge under the bonnet :roll:
DaveM wrote:Do you mean mounting the guage, or how to "plumb" it up?
Sorry I should have explained I need somewhere to plumb it into The guage is mounted on the pillar and the vac line is just sitting there waiting to get plumbed in.
UBZ
Post by UBZ »
nzhunter wrote:also if someone could let me know which vaccuum lines i need to tap into for my battery voltage gauge that would be great
use a paper clip to connect to the blue vac hose on the back of the starter motor. then hold the positive wire from the alternator between your teeth and crank her over.
excellent voltage gauge.
turoa
Pyro Junior
Post by turoa »
Ideally somewhere on the inlet manifold (is the most accurate), but otherwise anywhere between the turbo and the inlet manifold. On my 80 i just teed off the factory led boost lights, but im not sure if a nissan has one?
flyingbrick
Post by flyingbrick »
Batteries only experience vacuum while sucking electricity from the alternator during charge via the negative (vacuum) terminal.
You are better off tapping into the +'ve (pressure) terminal or hose.
darinz
Post by darinz »
Call into my office on Reyburn Street and I'll show you if you want. Roost mortgages just down from the Mitsi dealer.
Pedro
Post by Pedro »
the above is only true for Japanese systems, British Lucas electrical items use a different system called smoke, if the Lucas product fails then the propellant, smoke, escapes, which indicates a problem, once the smoke has escaped the Lucas item is usually toast. :lol: :lol:
FORGE1
Post by FORGE1 »
darinz wrote:Call into my office on Reyburn Street and I'll show you if you want. Roost mortgages just down from the Mitsi dealer.
Sweet mate,
I will try and pop in today or tomorrow after 3pm if thats sweet?
Mine was origionally a non turbo engine and there is no boost light or anything like that i think.
darinz
Post by darinz »
I should be around, if not call me as I won't be far away. Phone numbers on the door if no one in the office.
