My Conversion is based round a set of Nissan Maxima 3L rear calipurs, I chose these becouse they have a cable attatchment for the handbrake, they have a minimal profile on the outside of the disk and
Right first off I stripped the old brakes
I cut the backing plate off to make it easyer to deal to the studs (which I'm replacing) and hell who wants to buy drums??
With this gone you can smash the studs out, as you take em out replace them with bolts, you'll find it easyer this way than trying to knock them out of the bearing carrier later
With them gone you can take the axle out of the axle tube, could be a good time to replace the bearings and seals if they need it
I did this with mine, but isn't necicery as most machine shops should be able to machine the hub flang down without removing the bearing
If your going with early hilux solid disks you'll need to take the hub down to the same size as the deflector plate bolted to the back of the hub other options you could look at include Pajero - Patrol disks as they have a deeper offset from the hub
Here's a shot of the hub flange showing how much came off
There is one downside with my disk calipurs they run a slightly narrower disk than the solid lux one so I took 2mm off to fit them while I was at it I groved them to help sustained braking and clearing mud
Thats enough for now, its now tomorrow I'll throw some more up later
Cheers Reece
