diff and transfer oils
hey all,just checked my diffs and transfer case oil level,front all good and clean,transfer i bit low but clean and rear low and starting to show signs of milky stuff,(bloody water), where in christchurch is a good not to high priced place to get oils for these,and what the best way of filling the transfer case,fill hole looks really hard to get to with a funnal.
Don't know anywhere in CHCH for cheap oil know "SuperCheap" are good on price up here
As for getting it in, go to the tool shops like Blackwoods/Paykels or Tool Zone and get a 0.5L sump vacum pump (around $20 on specail).... this has a long hose for getting into the hard to reach spots and being a vacum pump dosnt' leak so won't spill oil everywhere, good for gearbox's and transfercases as well
Cheers Reece
Cheers Reece
beware of them all... they make a mess and they suck (figuratively, not literally).
I use a pump (water) bottle with the white bit ripped off and a bit of rubber hose about 300mm long tied on to it. Unscrew the lid, fill with oil, screw on the lid, poke hose in hole, squeeze bottle.
Easy, cheap, fast and effective.
Steve
Steve
SupraLux wrote:beware of them all... they make a mess and they suck (figuratively, not literally).
Steve
i do the same but with a G force bottle
takes a little while as the hose to fit is quite small but doesnt leak
no no no.....
Get an old engine oil pump ( mines a Supra.. funny that !! ) stick a hose in the output and the drive shaft in an electric drill, pour diff oil in a 5L bucket and watch it go.... Fills the diff in about 30 secs.... no mess
But if you have to do it the messy way fill a 10L bucket with real hot water, toss your diff oil container in for 5 mins then it goes in hot and thin
SupraSurf wrote:no no no.....
Get an old engine oil pump ( mines a Supra.. funny that !! ) stick a hose in the output and the drive shaft in an electric drill, pour diff oil in a 5L bucket and watch it go.... Fills the diff in about 30 secs.... no mess![]()
Which goes to show how often you do your diff oils
...its been sitting down at the shed for the last year I think...
SupraLux wrote:Which goes to show how often you do your diff oils
And you still used a plastic bottle ?
Excellent I thought I'd lost it, when you back at the shed, my front axle is completely apart at the mo so will need to refill soon....
Have you thought about additives to prolong the life of the oil and the component. Unless its LSD have a think about it and the gearbox. I was surprised by the condition of the oil when changed and the diffs when pulled apart. Don't put any in the transfer case though.
Al
Al
I have one of those pumps that fit onto any 4L bottle of gear oil. About ten bucks from SuperCheap. I leave the pump on the bottle between jobs to keep it clean. And like Supralux said it alot quicker when the oil is warm/thin. I just leave the oil in the sun or inside a warm engine bay with bonnet down and motor off for about 30mins before pumping.
Have welding rods will travel
Al, following that thought have you ever wondered why oil companies don't just put those additives in the oil in the first place?
two words... "snake oil"
They do nothing the oil isn't already doing, or in some cases make the oil less effective.
Perhaps they just know that additives prolong the life of the oil, which means less oil changes, and less money for them
Either way, are all additives bad? I use Moreys oil stabiliser, and often wonder if I should be....
I think each one needs to be taken on its own merits... google them and see what other people think, then make up your own mind.
I just figure if you use a good quality oil and do regular servicings then theres no need to use additives.
I'm sure there are exceptions to the rule, but the reading I have done suggests theres not much point to most of them... I'm sure if they were any good oil companies would produce a more expensive oil with those additives instead of letting other companies take a slice of the pie...
My 2c
Steve
My 2c
Steve
I see your point Steve, but oil companies do make oils with additives in them. I have used them for years in many different applicantions like boat motors, trailbikes and bigbore road bikes, cars and 4wds. I too was very suspect of claims, but decided to try and make my own decisions. I believe engine can run cooler and smoother, prolongs oil life especially what we do to trucks. True there are "snake oils" out there, but there is also some really good shit as well. I reckon it helped my engine to cope with running 3/4 hot for 8 days through the back of lake wakatipu at new year with no complications, just a really good clean out.
Al.
Al.
You missed the point somewhere I think... ditch the funnel... fit a bit of rubber hose to the end of the squeeze bottle and poke the end of the hose in the diff fill hole so when you squeeze the bottle it goes straight in...
Doing the funnel thing is frustrating and demoralising... been there, been frustrated... been demoralised
Steve
Steve
