wtf is this
Posted: Wed Feb 17, 2010 8:35 pm
by flyingbrick
WTF is this. Says NGK spark plugs
but i have a diesel so am a bit stumped.
Maybe Glow plug timer?
Re: wtf is this
Posted: Wed Feb 17, 2010 8:39 pm
by skid
its the add on you asked for when you got the truck
QGS-I
Queer, Gay, Stupid - Idiot
Re: wtf is this
Posted: Wed Feb 17, 2010 8:41 pm
by tallsam66
This is a system that controls the power distribution to the glow plugs in order to improve the starting performance of a diesel engine. It contributes to a clean-air environment by supplying power to the glow plugs even after the engine has started to thereby improve ignition performance.
Re: wtf is this
Posted: Wed Feb 17, 2010 9:01 pm
by flyingbrick
Thanks dude
Skid that was not helpful at all.
OK now what about the GREY box below the radio inside the dash. It was bolted to the RHS of the internal steel frame.
It seems to be the unit which emits the "BEEP BEEP" when I go into reverse............................does it do anything else? What does removing it achieve?
Re: wtf is this
Posted: Wed Feb 17, 2010 9:03 pm
by skid
flyingbrick wrote:Thanks dude
its the roadrunner device
just pretend you're Wile E Coyote and you'll be right dude
Re: wtf is this
Posted: Wed Feb 17, 2010 9:13 pm
by MNC
skid wrote:its the roadrunner device
Re: wtf is this
Posted: Thu Feb 18, 2010 12:52 pm
by DieselBoy
Re: wtf is this
Posted: Thu Feb 18, 2010 1:05 pm
by BrentC
skid wrote:its the add on you asked for when you got the truck
QGS-I
There you go Mark as Moderator -
is this bit off topic? or could it just be the chemo coming out of me
Re: wtf is this
Posted: Thu Feb 18, 2010 5:29 pm
by coxsy
hang in there brent
Re: wtf is this
Posted: Thu Feb 18, 2010 6:03 pm
by Shane
was yours a auto to start with?
Re: wtf is this
Posted: Thu Feb 18, 2010 6:25 pm
by flyingbrick
still auto bro
Re: wtf is this
Posted: Thu Feb 18, 2010 7:02 pm
by aroma
if you get that little black box wet the truck starts funny and the glowplug lite does really random flashes
i covered my will sealant after I dryed it and hasn't played up since
stupid place to put it under the seat! well guess thats where your is located
Re: wtf is this
Posted: Thu Feb 18, 2010 7:11 pm
by flyingbrick
nah mine is behind plastic pannel to right of gas pedal
Re: wtf is this
Posted: Fri Feb 19, 2010 9:59 am
by GQTROL
flyingbrick wrote:nah mine is behind plastic pannel to right of gas pedal
When you do the cab swap, make sure you relocate it up high under the dash, but orientated so the plug is at the bottom. We had it upside-down originally and when it gets wet, it fills with water and it won't glow for starting.
