it has new airflow snorkel
40mm body lift
50mm spring lift new rear shocks
motor has been striped down and freahened up new rings and bearings all toralances checked, heads has new valve stem seals and relaped new gaskets all round new caps and seals on injector
cranks was ploshed bores where honed
new water pump and cambelt
less then 5000km since all work has been done have moved on to a double cab hilux
gearbox is good apart from it pops out of first sometimes
new clutch bout 1000km ago
has bullbar with ramsey 8000 pound winch with in cab control
lsd rear diff
has 31 tyres tread getting down, as i was running 33s on it
has no rust that i know of
photos come when i can work out how
$4500
phone or txt questions to 0212399650 cheers karl
all so have a 87 surf with a rover v8 with hilux gearbox running with a full internal roll cage no cert new exhurst lsd diff tight body bit ruff offers and plus a surf cab half cut down
location is west auckland viewing welcome
photo is with out body lift and bullbar is different to one in photo
