Hi
I have turbo'd my 3b. I guess the best extra I did was the 2 1/2 inch exhaust added at the time. I believe that has contributed to more torque in the 1000 to 1500 rev range.
The other things I did was a boost and EGT gauges. I mostly only boost to 5 lb. the gate is set to a max of 7.5 approx. EGT I only let max at 500 then will take foot off the gas.......
I used a Aust kit through the local turbo guy. But lots of ideas and specs on using C26? turbos on
www.IH8mud.com You will have to get the ratio of the turbo's air to exhaust gas right.
