Bead Lockers in CHCH
Hey,Where do you Chch people get your beadlocks done,got a qoute for $200 a rim from a 4wd buisness.Just wondering if this is a reasonable price.
Thanks,Rob
Thanks,Rob
- skid
- Tyre Man
Re: Bead Lockers in CHCH
Howat Engineering here in Welly is currently charging $130 per rim I think (you supply rims)
and you could check out 4wdbits.co.nz as a comparison of costs as well
Elite wheels
(021) 02388443
(021) 02388443
Royce Clive Engineering
Cheers fella's...I guessed the 4wd buisness would just outsource the job so I will have a shop around
Cheers,Rob
Cheers,Rob
elite wheels
What sort of use are they going to get? I only ask as the trials guys really use their beadlocks, but if you are club trucking or doing coast type stuff do you really need them?
I only say this as I run 39.5" tyres on 8" rims at 4-10 psi and have never lost a tyre off a rim. If you are going to do it though why not look at the internal air bag type units, I know H20LVR has them on his rig and I am sure others do as well, and at least they actually push on the tyre bead on both side of the rim.
My 2c anyway, I am sure plenty will disagree, but I don't care
rokhound wrote:If you are going to do it though why not look at the internal air bag type units, I know H20LVR has them on his rig and I am sure others do as well, and at least they actually push on the tyre bead on both side of the rim.
I agree with this. Mechanical beadlocks hold the outside bead on but not the inner bead and have to be certified for use onroad (correct me if I am wrong) whereas the internals dont,its just a small tube (okay its a bit more complicated than that but its still a tube.) and if you stuff a rim, its easy to fit in the next one (if you stay the same size that is).
- mud_slinger
niblik wrote:got my internal airs from 4wd accessories on montreal street..
on that truck thats been in the garage for how long.......? or is it actually moving now
needs more curry
0272593533
0272593533
Yet again some sweet advice from the ore boys!..I know staun do them,But i'm guessing they quite expensive?,Is there any other brands worth a look?
Cheers,Rob
Cheers,Rob
- rangimotors
never had a set of bead lockers myself but have had mates with them, from what i have seen they are bloody near impossible to balance and you wouldn't want to drive them on the road much faster than about 50km/h for those reasons i have decided to avoid them and go for those "in tyre" lockers as above. At this point I have never bothered and i have never knocked a tyre off the bead, only a matter of time i guess but i always run between 10-15 psi on my simexs and don;t seem to have problems so at this stage i have decided to just carry a spare and take my chances.
what kinda ringding garage did your mates ones? never had problems with balancing NI ones
you wont ever knock a tyre off running 10psi. Running decent pressures is when you actually need em. For most wheelers I really wouldnt bother with beadlocks. Just a set of tubes will do fine
- niblik
- Sausage Shack
as i said.. these guys do an item, internal air, the same as the staun's but not quite as expensive..
give them a holla..
- skid
- Tyre Man
turoa wrote:what kinda ringding garage did your mates ones? never had problems with balancing NI ones
yup, I'm with him
8psi on beadlocked rims at 140kph and no issues at all
Cheers niblik will go check them out
niblik wrote:niblik wrote:got my internal airs from 4wd accessories on montreal street..
give them a holla..
