I am just resetting the valve/rocker clearances to see if i can quiet the motor down a wee bit...initial measurement of them seems rather loose.
Ive done the first 6, but cant do the others..
Terry wrote:Petrol one's 27mm, diesel probably the same? I usually just put it in 3rd or 4th and roll it forward a bit to turn the engine...
but I've got a socket you can borrow, I'm in Waikane all day Monday but driving to Wgtn on Tuesday morning could drop off then if you want or you could collect. - pm me if you want.
cheers, Terry
