Driveshaft Angles
brakes-shocks-lockers-etc
2MEKE
Driveshaft Angles
Post by 2MEKE »
What is the general consensus regarding these driveshaft angles?
Flange to flange it approximately 670mm.
Is this going to work or will I run into problems? If so what will they be?
The 2 things that come to mind are....
- how will the pinion bearing go for oiling...will the diff need to be run with more oil then normal?
- will there be issues with an increased oil level?
