ln65 non powersteer steering shaft
this is what you need if bodylifting your 60 series surf or hilux its longer than the powersteer model ones that drop out of the joint once the bodys lifted. used it on my yn60 but have changed the setup completely now so no longer needed paid $50 from ace4x4 couple years back they gettin hard to find open to offers.
Re: ln65 non powersteer steering shaft
whats the length measurement? cheers
455mm also have an ln61 which is 415mm
thanks
thanks
antsarooney
Do you know how long the power steering ones are?
around 400-415mm i think its mainly the beam axle surfs that they fall out of cos my old ln61 the shaft was only just long enough but my beam axle surf shaft fell right out my measurements dont include the universal joints as i dont have them
iv got one that has had a piece welded in. (angle cut and then sleeved for strength). Was made for a 75mm body lift on an ln65 hilux
antsarooney
I was thinking of doing a 30mm bodylift on my ln65 as i only run 32's and i was hoping i would'nt need to worry to much about things falling out.
you mite just get away with it with the 50mm mine just slipped right out and was about a 5mm gap between shaft and uni joint thats why i had to get this
