Page 1 of 2
easter weekend 2006
Posted: Fri Apr 14, 2006 6:43 pm
by mercutio
i decided to run an experiment this weekend last timei was supermarket shopping i bought 3 litres of fresh cheap cooking oil.
i did a bit more research last night and found out that mercedes diesel engines should be able to start when cold on straight cooking oil unlike most other diesel engines
so today i disconnected the feed and return lines from the tank and put them into my bottle of basics cooking oil and i started it no worries at all even drove it around the block no noticeable power loss but it does smell funny
i must admit then engine was warm and i didn't bleed the engine so it would have been starting on diesel so turned it off and i will leave it over night to see if it starts in the morning
this is where i found out about mercedes diesels being able to start on cooking oil
http://www.plantdrive.com/
Posted: Fri Apr 14, 2006 6:51 pm
by WACKO
haha. thats pretty cool. is it just mercs you reckon? my achievments for today was putting in my raised springs in the rear. i like the look! tomorro the balljoint flip and change a wheel bearing i hope.
Posted: Fri Apr 14, 2006 7:17 pm
by mercutio
well i get the impression you can start most diesels on vegetable oil but the injector pumps don't like it and eventually die
Posted: Fri Apr 14, 2006 7:31 pm
by hiriklux
why not just mix them in the tank???????
Posted: Fri Apr 14, 2006 7:35 pm
by mercutio
i dunno but i don't need to bother
Posted: Sat Apr 15, 2006 8:43 pm
by WACKO
ball joint flip is done!
and no more rear bumper.
Posted: Sat Apr 15, 2006 10:06 pm
by DJ
errrr not exactly ... start on diesel then change to cooking oil and just before shutting down change back to diesel.Just like CNG. As for pumps, Lucas ( princes of darkness) and CAV types, die using oil instead of diesel all other types no problems
ops weekends achevements ( keeping within this thread) went to work, came home, went to sleep .. went to work, came home, went to sleep..........
;-p
Posted: Sun Apr 16, 2006 12:30 pm
by wopass
so far...
driven back from gisborn
picked up all the dog shit on the lawn
emptied the bus (commy s/w ) of all the holliday contents
tried to catch up on all the new goings on here
now im about to mow the hay paddock that i call a lawn
Posted: Sun Apr 16, 2006 2:15 pm
by mercutio
well i was chatting to my old man about this yesterday afternoon and we were discussing filtration and he said i could use the gulf coast filter he used to use on his roadsweeper it uses a paper towel roll and filters down to 0.7 of a micron so that should get most of the rubbish and it is rather large so should work as a water trap as well it is designed to handle bypass pressure so using it as a fuel filter may be a little bit of over kill but i figure better to be safe than sorry i'll probably have to put an electric pump in though to help push it through
Posted: Sun Apr 16, 2006 7:57 pm
by Dazlinsky
I still dont undertand why you cant mix 1/2 a tank oil and 1/2 diesel??
I know of a guy who mixes the oil with some alcohol and has no problems, starting up or running!!! the only down fall is smelling like a fish and chip shop!!!!
Posted: Sun Apr 16, 2006 10:12 pm
by mercutio
you may be able to do that but i don't need to so i'm not going to
Posted: Mon Apr 17, 2006 11:25 am
by mercutio
oh yeah i forgot to mention i got my spare engine on saturday the only reason i bought this one as well is it has a turbo so i'll bolt that and the injector pump onto my wagon sometime in th near future
and last night while i was contemplating life the universe and everything i realised the spare motor still has the power steering pump on it hmm maybe i could use it to drive a hydraulic winch me thinks
Posted: Mon Apr 17, 2006 3:38 pm
by Mattman
On friday I helped reroof the mother in law's house and put in a skylight in the lounge with 3 of my brother inlaw's.
Saturday was chores day, lawns, edges etc.
Sunday was relaxing day, motorsport in the afternoon.
Today I fitted the manual hubs to my Surf thanks to those who responded to my thread yesterday!
Matt.
Posted: Mon Apr 17, 2006 4:22 pm
by lilpigzuk
changed shitty nappy then bought home hilux running gear from work, changed another shitty nappy and dropped of Simex's to mates tyre shop to get removed off some dirty ole Jeep rims. For something else to do I changed a shitty nappy and put a few things on trademe to fund other bits I want to buy. While changing another shitty nappy (and talking to Chris - but not at same time
) I/we decide that Lil Pig shall go down the rover running gear path instead of hilux..... Oh the joys of daydreaming about 4wding
Posted: Mon Apr 17, 2006 5:21 pm
by DaveM
Thursday night = drive to Dunedin
Friday = 4wding
Saturday = 4wding
Sunday = start trip home
Monday = get home, wishing I'd gone 4wding Sun/Mon
Posted: Mon Apr 17, 2006 6:57 pm
by nz4x4
got my new seats in place ruffly (on standard runners) so i can now fab up some new fixed mounts.
got a steering boss kit and sportline steering wheel and fitted it all up.
Posted: Tue Apr 18, 2006 7:30 am
by MATT4U
Posted: Tue Apr 18, 2006 8:35 am
by Rangielux
Did some track maintainance in Pureora on Sunday in a part of the park that is becoming a real good spot
Posted: Tue Apr 18, 2006 10:09 am
by krawlr
wheres that rangielux?,i see north blocks got a few and doc want people to use that area more,am i correct?
just got back from up there......had a ball......
Posted: Tue Apr 18, 2006 1:19 pm
by Rangielux
Yeap, We've done alot of work up there and spent quite a few dollars. All through many hours of co-operation and meetings with doc.
Guiding a couple of Auckland clubs around there next w/end.
Happy to do a ORE trip end of May/June if a few put their hands up to go (I normally know if a club group is going to be around on a weekend so can get a quieter day,w/end to suit)
;-p
Posted: Tue Apr 18, 2006 1:54 pm
by wopass
ill be into that .....
hang on...
have to fix my missile first
unless i come allong on my bike
Posted: Tue Apr 18, 2006 6:32 pm
by mercutio
hmm i need to get my tyres as soon as possible
Posted: Wed Apr 19, 2006 10:23 am
by Shariya85
umm friday... had a cool little get together at my house. good turn out, and we all managed to get pissed even though it was good friday and you couldnt buy it anywhere (lol that is an achievement in itself!)..
saturday... played singstar, drank wine, went to catalyst and danced to techno. achievement for that night was getting into a club.. even though it was gay. then stayed the night at my hot hot friends house (another achievement).
Sunday.. recovered.
Posted: Wed Apr 19, 2006 12:18 pm
by DieselBoy
Went down to Nat park, did some exploreing, highlight was that i drove up the Tongariro river as far as i cud saftly with one vehicle.
Take two vehicles next time
Definatly in on the ORE Pureora trip, love that place, good tracks everywhere!!!!
weekend in north block
Posted: Wed Apr 19, 2006 12:24 pm
by TeLexs
Just had the weekend out in north block with the Taupo club . Went out friday , left Taupo 8.30 am bit of a hall out there loaded up with fuel (before the price went up again) made camp in the new spot , Doc have put aside for 4wds . Very nice view over the 4wd area . Stayed one night had a ball . There is some good tracks out there that loop back on to others and some good mud holes . Nice to have a new place to play and thanks to all involved in getting the access opened to 4wds
Does any one know if the track goes right throught to the Hamilton side if you get across the river where the bridge once was .
Cheers Klem
Re: weekend in north block
Posted: Wed Apr 19, 2006 2:55 pm
by Rangielux
TeLexs wrote:Does any one know if the track goes right throught to the Hamilton side if you get across the river where the bridge once was .
Cheers Klem
It used to go out to the old Ngaroma mill years ago, but there is a farmer at the other end that has denied all access to everyone for years and we are ok with the access from the bottom end cause it's central to other areas and accommodation in the park. Doc didn't want us to stir him up anymore either (which kind of sounds like they have had their moments with him too) Oh and Doc wont allow any vehicles in rivers at Pureora - its one of their biggest no no ' s and the best way to get up their nose (just so everyone knows to be carefull with that)
Glad you found it good
Posted: Wed Apr 19, 2006 3:03 pm
by krawlr
DB/ you werent headin back on sat were ya
Posted: Wed Apr 19, 2006 3:07 pm
by TeLexs
Thanks for that info , Wont go there then lots of places to play out there , with out upsetting a farmer.
Cheers Klem
Posted: Wed Apr 19, 2006 4:00 pm
by DieselBoy
krawlr wrote:DB/ you werent headin back on sat were ya
Yeah, i thought i recognised that SAS'd Surf i passed in the opposite direction, on that hill up onto the plateau on the Desert Road!!
Had been round the other side of the mountian looking for any interesting places in the Erua Forest . We were heading up towards the Tukino (sp?)ski access co's i heard there was a way to sneak round the gate (which there was) and then onto the Tongariro River from there.
I only clicked who you were as you passed lol
Posted: Wed Apr 19, 2006 4:20 pm
by krawlr
