KZN185 surf
Posted: Thu Mar 25, 2010 3:24 pm
by mudlva
hi all had the timing belt replaced 10k ago and the clock has just ticked over the 200k and the little timing light has just come on
how do i switch the ligth off??
apart from using a little bit of tape over the light position on the dash
Re: KZN185 surf
Posted: Thu Mar 25, 2010 4:15 pm
by 1rugger
the earlier hilux's have a button which can be accessed on the cluster by pulling a small rubber bung out which is about the same location as the odometer reset but off to the left. if that makes any sense
Re: KZN185 surf
Posted: Thu Mar 25, 2010 4:48 pm
by mudlva
cheers I justed looked and unfortunately there is no little bung thingy on the dash at all
keen for other susgestions tho
Re: KZN185 surf
Posted: Thu Mar 25, 2010 5:26 pm
by mudbugga
If its not a digital dash, you'll need to pull dash gauge cluster out and swap screw over to reset the light.
Re: KZN185 surf
Posted: Thu Mar 25, 2010 8:02 pm
by gimmemud
Pull the bulb out?
Re: KZN185 surf
Posted: Fri Mar 26, 2010 3:17 pm
by mudlva
gimmemud wrote:Pull the bulb out?
that just might be what happens if the dash has to come out and it start looking too hard
Re: KZN185 surf
Posted: Fri Mar 26, 2010 5:47 pm
by mudbugga
Its a 10min job.
And to pull the bulb you'll have to take out the cluster anyway.
Re: KZN185 surf
Posted: Fri Mar 26, 2010 8:07 pm
by mudlva
mudbugga wrote:If its not a digital dash, you'll need to pull dash gauge cluster out and swap screw over to reset the light.
sweet then thanks for that info
will up date done
