Pajero - Stuck rear brake pistons
chevrolux
Post by chevrolux »
Just swappng the rear pads on the paj and cant get one of the pistons back far enough. Used the BFH (big f****n hammer) also tried the old g clamp to wind it back. Neither way worked. And yes i did undo the bleed valve.
ANY IDEAS???!??!!
Lynx
Re: Pajero - Stuck rear brake pistons
Post by Lynx »
has it got the handbrake as part of the caliper??
Cheers Daniel
chevrolux
Post by chevrolux »
yup. disconnected the hand brake cable
Lynx
Post by Lynx »
pretty sure you have to wind the piston back in then, as its on a thread for the self adjusting hand brake
Cheers Daniel
Pedro
Post by Pedro »
chevrolux wrote:Just swappng the rear pads on the paj and cant get one of the pistons back far enough. Used the BFH (big f****n hammer) also tried the old g clamp to wind it back. Neither way worked. And yes i did undo the bleed valve.
ANY IDEAS???!??!!
if the piston has notches in front face then the piston is screwed back into place, not pushed back
Pedro
NJV6
Post by NJV6 »
My Pajero ones just push back in (94 disc brake rear) as the handbrake is completely seperate from the calliper. so doesn't need to be disconnected.
chevrolux
Post by chevrolux »
ANY IDEAS???!??!!
Pedro
Yes! There are notches in on the piston. Thanks Pedro! Will try that tonight
Return to “Mitsubishi”
