swivel hub play
swivel hub play
Guys just got knocked on a warrant cos of a wheel bearing on my SWB GQ. Did that today (repco $170.00 for one side!!!) and now there is still a little bit of vertical play. Checked and its moving in and out on the swivel hub. Is that just a bearing top and bottom. Easy to do? Read the other posts about these but not sure if this is a whole kit issue or an easier fix?
Re: swivel hub play
Hombrey wrote:Guys just got knocked on a warrant cos of a wheel bearing on my SWB GQ. Did that today (repco $170.00 for one side!!!) and now there is still a little bit of vertical play. Checked and its moving in and out on the swivel hub. Is that just a bearing top and bottom. Easy to do? Read the other posts about these but not sure if this is a whole kit issue or an easier fix?
Yeah there not expensive about $18 each (unsealed)
GU patrol 35s ect.
Re: swivel hub play
Dont go to RIPCo as it is tthe most expensive place around look in your phone book for BNT (Brake n Transmission
(021) 02388443
(021) 02388443
