WTB: Hilux front hub
To suit 85 beam axle hilux as sheared a couple of the studs that hold the FW hub in place. I think it was because only a couple on that hub had cone washers.
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
Re: WTB: Hilux front hub
Dont buy a new hub just drill a hole thru the broken studs an try using a stud extracter to screw them out then get new studs an cones
Didn't barbie drive a jeep??
Fakey wrote:Dont buy a new hub just drill a hole thru the broken studs an try using a stud extracter to screw them out then get new studs an cones
Cheers for that, tried that but stuffed one of the threads. Have located a 2nd hand one anyway but now know how to extract next time.
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
check the freewheeling hub housing too coz when I did mine the stud and dowel holes stretched and distorted so I had to replace the hub and the free wheeling hub
