hey guys,Im looking for a portable compressor to pump the tyres up after deflating for sand driving.what are some things I need to look out for?
I see repco has a 120psi 12v 20L/min for $40 and also a 150psi 12v 40L/min for $ 70 this one has connections to go directly on the battery (if that makes a difference?).
Are these gonna do the job?
What is a good portable air compressor for pumping up tyres.
local buoy
- Driver/Navigator
Re: What is a good portable air compressor for pumping up tyres.
what size tires are you inflating, and from what pressure? generally the smaller output compressor models also have a low duty cycle, so they get hot and cut-out more regularly......
get something that is above 55LPM flow rate, bushranger do a great range of portable units...
- malfunction
This one is awesome http://www.4wdbits.co.nz/ProductDetails ... uctID=1483
I have one myself as do 2 of my mates
Mal
021 0666826
021 0666826
looks very similar to the ones from supercheap - terrain tamer brand maybe? They do big specials on them in their mailer thing every so often.
forget those cheap $70 jobs. they are only suitable for a small car tire at best. you would be struggling to get one stock standard 4x4 tire pumped up let alone 4 of them.
these come out under different names, sometimes with different features/fittings.
i have project typhoon which is looks the same, but i had to mod it a bit due to a design fault it has. also the stock cable on a lot of those is fairly crap.
just remember to weigh in the cost of mods and cabling etc. it can work out not far off what an ARB is worth and the ARB is a far better kit.
i find our dive bottle setup works incredibly well and fast
anyone used these? they sound good.
150lmp at 150psi has gotta be good!
http://www.4wdbits.co.nz/ProductDetails ... ductID=925
LN130 Surf: Coiled SAS, 35" BFG M/T's, Lifted, Rear Lockright, Snorkel, CB, On-board air
Soon to be 3.8 commy powered, front ARB Air Locker, custom bar work, winch...
Engineer wrote:anyone used these? they sound good.
as mentioned a couple of posts up
http://www.offroadexpress.co.nz/Forums/ ... ta+typhoon
edit: added image to your post.
local buoy
- Driver/Navigator
we have a dive tank set up as well but cant really take that with us if we want to bring home paua.I dont live far from the quarry(WGTN) so not that big a deal to drive home on 20psi(I guess?) then pump up. just thought it would be handy if I needed to while over the gate.
and the day you need is the day you left it at home. another reason i like it bolted to the ute.
