fuel filter restriction alarm
Posted: Tue Apr 06, 2010 7:01 pm
any got or even know of an alarm/light setup for fuel restriction ??
i see a few places make gauges, but i don't really want fuel lines into the cab. just an idiot light would be fine.
i did a diesel fuel filter change and it was clogged up with light brown slime and a bit of water in the bottom. thats the 2nd filter i've had clog up (first may have been filter failure). problem is these injection pumps do not take kindly to lots of inlet fuel restriction (high vacuum). i'm told they blow an internal seal which causes the rest of the pump to grind itself to bits.
or i may look at pusher pump and a pre filter.
