Surf suspension / lift
brakes-shocks-lockers-etc
Greeny
Newbie
Newbie
Post by Greeny »
Just wondering if anyone can help - I was wanting to lift my '86 Surf maybe 2 or 3 inches but it has independant front suspension and I don't know how to go about it/ if it can be done.
Any wise words would be appreciated
MATT4U
Post by MATT4U »
Lift springs in the rear, wind the torshon bars up at the front
turoa
Pyro Junior
Post by turoa »
I have a 75mm body lift for sale...
SupraLux
Complete Bastard
Post by SupraLux »
IFS has limitations, but a reasonable lift can still be achieved.
either extended shackles in the rear or replace the rear springs with 50mm lifted ones
Tweak the torsion bars in the front to suit, while maintaining a safe amount of reserve out-travel
Fit a 35-50mm body lift... Turoa, your kit might be more work than it first appears due to steering shaft slip requirements and fuel fillers, gear change, handbrake stretch, brake lines in the front etc... do you know what other bits the guy that fitted the lift added to avoid those issues?
Have a read here, might help with some basic stuff:
http://www.offroadexpress.co.nz/modules ... pic&t=1453
Steve
