Wireing up a winch
You Get That
Wireing up a winch
Post by You Get That »
I just got a GEW 9000 winch any idea how to wire it up?
if someone had a wireing diagram that would be great or just pictures and a talk on how you did it would do.
Thanks
Addicted to suzukis....
gimmemud
Re: Wireing up a winch
Post by gimmemud »
Long red wire to battery positive, other colours from solenoid to the colour on studs on the winch. Little black wire from solenoid box and big long black wire to bolt on bottom of winch. other end of big black wire to battery negative.
Edit: Assuming it's the same as ewx 12000 and about 5 other winches i've wired up
UBZ
Post by UBZ »
long red to battery +
blue to winch A terminal
yellow to winch F1 Terminal
red to winch F2 Terminal
Winch Earth (black) to battery -
solenoid pack , center pin to earth (battery -)
left / right terminals require +12v from in/out switch (can't remember which way round)
You Get That
gimmemud wrote:Long red wire to battery positive, other colours from solenoid to the colour on studs on the winch. Little black wire from solenoid box and big long black wire to bolt on bottom of winch. other end of big black wire to battery negative.
Aha This sounds good thanks mate.
Return to “Tool Shed”
