9th - 12th April
Posted: Sat Apr 10, 2010 10:25 am
by slo_mo
Started to make up some storage in the back of the bighorn so dirty theives can't see what I don't have in the back, time to go cut down a tree in the back yard (hope it falls the right way)
Re: 9th - 12th April
Posted: Sat Apr 10, 2010 11:14 am
by coxsy
got a permit to cut it down
Posted: Sat Apr 10, 2010 1:18 pm
by kbushnz
Finished cleaning the truck after a few trips...
Wife happy to get it off the front lawn.
Then once dry, park it up and pull out the factory dump pipe and make a bigger one...
Calvin
Posted: Sat Apr 10, 2010 4:08 pm
by 92 safari 17
saturday: Painted secound set of rims black and mounted a recovery hook to the back of my patrol,
sunday: goin to a 4x4 tag along
Posted: Sat Apr 10, 2010 8:34 pm
by slo_mo
cut the tree down with no damage to property of myself. No permit needed in this case.
Posted: Sat Apr 10, 2010 8:55 pm
by niblik
made exhaust, did shock bar, rods runs, show day..
in shed tomoz.. hopefully..
Posted: Sat Apr 10, 2010 9:35 pm
by coxsy
removed the hi volume ARB pump. fitted small diff locker pump instead
Posted: Sun Apr 11, 2010 3:47 am
by geckoadventure
Hi im back - managed to get ourselves on TV From Malaysia you can check
http://www.4x4earth.com.au/watch-4wdtv/?e=216It starts with us beating the crap out of a Honda in a carpark
Tomorrow im back in the water after about 6 months of no riverboarding.
Posted: Sun Apr 11, 2010 6:41 am
by MNC
coxsy wrote:removed the hi volume ARB pump. fitted small diff locker pump instead
WHY?
Posted: Sun Apr 11, 2010 8:06 am
by coxsy
the hi volume is a 12 volt 23 amp, to much draw from one battery, james can use it his 40 instead
pump in
switches in place, got to have a main power switch
new site for the 40s battery
Posted: Sun Apr 11, 2010 4:29 pm
by kbushnz
As I said earlier, pull out factory dump pipe. Yeah right...!!!
Removed front pipe ok... Few bolts seized, bit of biffo and they came loose.
Three bolts on the flange all stuck fast and corroded away.
Split those nuts
Now for the dump pipe on the turbo..
Had it all apart about 5 years ago... Bit tight but do-able.
Got them all bar one
And the nut is stuffed...All corroded away.
So its Exhasut manifold off and turbo out.
More stuck nuts....
Finally finished..
Now I can get back to what I was wanting to do.
Calvin
Posted: Sun Apr 11, 2010 4:59 pm
by coxsy
when you put it back together cooper coat the nut and threads
Posted: Sun Apr 11, 2010 5:15 pm
by wopass
went to Whitianga Festival of speed for the weekend. was awesum.
Posted: Sun Apr 11, 2010 5:23 pm
by vvega
my FOA's arrived today
sat them in the truck took pic's
Posted: Sun Apr 11, 2010 5:25 pm
by kbushnz
Copper coat...
Yeah I did that last time..Heaps of it....
Works good on cold bolts.
But I think it gets too hot for copper coat so have some new stuff.. Nickel based.. Worked fine on the pyro fitting.
See what happens..
Calvin
Posted: Sun Apr 11, 2010 7:32 pm
by sibainmud
Another great day at Woodhill on Patrol. Cooked winch control pack....gives me something to do in the week.
http://www.youtube.com/watch?v=vSWb890b5x4http://www.youtube.com/watch?v=TnblYwzvisU
Posted: Sun Apr 11, 2010 8:11 pm
by coxsy
you found mud up there
Posted: Sun Apr 11, 2010 8:16 pm
by J_Dub
worked on truck, got a bit done, and finished making a mould for VN GP A Commodore centre console to fit a BM shifter
Posted: Sun Apr 11, 2010 9:14 pm
by sibainmud
Posted: Sun Apr 11, 2010 9:32 pm
by snork
what happened to the last 4wd on the last video? did it not make it up?
Posted: Sun Apr 11, 2010 9:34 pm
by sibainmud
Posted: Sun Apr 11, 2010 9:45 pm
by sibainmud
