sealant on new head and gasket?
Posted: Mon Apr 12, 2010 12:33 pm
by lincooln
hey all, i just have a quick question that i need to know as soon as i can,
I just have a new head and gasket for my mazda and was wondering when i put it on do i need to use gasket sealant / glue? its a metal headgasket (monotorque) and its a 1989 mazda 626 2.0L FE motor, alloy head and cast iron block.
I know its a noob question and not 4wd related but i just want to make sure.
Lincoln
Re: sealant on new head and gasket?
Posted: Mon Apr 12, 2010 12:48 pm
by haynzy
lincooln wrote:hey all, i just have a quick question that i need to know as soon as i can,
Lincoln
dont use anything other than the gasket itself :wink:
Posted: Mon Apr 12, 2010 12:51 pm
by lincooln
ok, thanks, thought so. no work today so will get it done.
Lincoln
Posted: Tue Apr 13, 2010 9:07 pm
by Landy Rover
As above, also, even being a monotorque gasket, I highly recommend loosening and retorqueing after its been hot and cold a few times or after 500kms or so. They do go down further and those engines are prone to doing in the gasket between cylinders.
Posted: Wed Apr 14, 2010 5:04 pm
by lincooln
Landy Rover wrote:As above, also, even being a monotorque gasket, I highly recommend loosening and retorqueing after its been hot and cold a few times or after 500kms or so. They do go down further and those engines are prone to doing in the gasket between cylinders.
I will make sure I do that then, just another quick question, what about the other gaskets, ie the intake, distributor etc?
Lincoln
Posted: Thu Apr 15, 2010 8:47 pm
by Landy Rover
You can put sealant on those, mainly inlet manifold, thermostat housing, a light smear of silicone gasket RTV, dont over do it :)
Posted: Thu Apr 15, 2010 8:51 pm
by lincooln
ok sweet as, thanks for the help guys
