What Im wondering is how much different the 3f and the 3F-E engines are?
Would it be possible to convert a 3F into a 3F-E with the right parts or is it possible to bolt a 3F-E directly into an Fj70?
The next question would be is there any advantage to doing such a thing... ie improved power or fuel economy?
Just an idea Im toying with.
Ideas????
Kempy.
How do able is this FJ70 3F idea...
- mudlva
Re: How do able is this FJ70 3F idea...
the engines are the same the E stands for fuel injected so at a guess the engines are the same externally unsure about the internals thu
and playing with the injection unit you should be able to get a heap more HP than the old carby system
Better economy, will keep running on more extreme angles, an it will be easier to turbo
I think it was on the pirate forum someone put a 3f-e head on a 2f block in a 40 an turboed it
Didn't barbie drive a jeep??
Yeah I knew it was just an injected version. Just wasnt sure how compatible the parts were. But thats good to know.
- mudlva
yes the 3FE head will bolt onto the 2F block but i thought this was to get better compression
althu when inducting I thought the general rule was to reduce compression because the induction was going to supersede the compression rate anyways
just my thoughts the 2f is a stronger block and crank set up thu
Does anybody have the link for the pirate forum swap? Im not sure where to find it on that site.
- mudlva
PM dieselboy he seems quite knowledgeable in these areas
Sorry wasnt pirate was here http://www.fj40-2f-eti-locked-n-loaded.com/stage3e.html
