body lift
Re: body lift
bout as hard as using the search function on ORE
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=22&t=18263&hilit=80+series+bodylift
- niblik
- Sausage Shack
Re: body lift
badnuz wrote:bout as hard as using the search function on ORE![]()
obviously its like rocket science?
Re: body lift
fatdog wrote:any tips
on using the search function? or doing bodylift?
where in NZ are you someone close to you ma be able to assist you?
Re: body lift
whatwhata (hamilton)
Re: body lift
bodylift on an 80 series is easier than using the search on ore...
Re: body lift
Hahaha u guys are mean......................
- mudlva
Re: body lift
yep i used a trolley jack
- flyingbrick
Re: body lift
how big was the trolly jack
- mudlva
Re: body lift
wasnt a very big one as i only did a little lift
only need a little jack to do little lifts
mind you you will need a big trolley jack if you want to do BIG lifts ah
- KIWI_TERRANO
Re: body lift
mudlva wrote:wasnt a very big one as i only did a little lift
This guy haha
When i did terrrano (didnt fit my surf one) I used a 4 ton jack for terrano did one side at a time then once both sides done measured to check square then tighten then took it for a race round mates track then double tightened
- flyingbrick
Re: body lift
so ur not leaving the jack in there then? how do you make the lifted side stay up?
Re: body lift
Little lift?????? i have seen the latest lift you did on an 80. i reckon that it had to be at least an 800mm body lift, and even more sideways.
Tony.
- KIWI_TERRANO
Re: body lift
just use the jack to lift body up and u undo all the bolts on one side jack it up put blocks and bolts in tighten then drop jack repeat on other side then check square then tighten all then in 1000km check tighten again
- flyingbrick
- KIWI_TERRANO
Re: body lift
the body lift ones...........
Re: body lift
I cheated, I used a two post hoist under the body, did them all at once..
5L+GT35@21psi= 223RWHP
5L+GT35@30+psi= 287RWHP....
Great tow Vehicle!
Great tow Vehicle!
Re: body lift
With only two posts to hold the body up does it wobble from front to back uphill/downhill styles?
- KIWI_TERRANO
Re: body lift
NJV6 wrote:With only two posts to hold the body up does it wobble from front to back uphill/downhill styles?
Ay ay????
- flyingbrick
Re: body lift
Yeah I'd definitely expect some cracking around the body mounting points when only using two posts!
Re: body lift
Big Will wrote:I cheated, I used a two post hoist under the body, did them all at once..
Two post hoist, ie, 4 out riggers.
Re: body lift
Careful guys, don't make your post count go up too fast.
- flyingbrick
Re: body lift
And you are doing what by posting?
I'm had a bit of fun, couldn't care less about my post count.
- mudlva
Re: body lift
flyingbrick wrote:And you are doing what by posting?I'm had a bit of fun, couldn't care less about my post count.
anyway nobody realy answered this chaps question
although my post count is increasing as fast as my nose on this subject
