Suzuki Samurai boss kit!!
Lebmob
Post by Lebmob »
Hi All, seem to be having trouble finding one, little own at a reasonable price, does anyone know if any other car makes might have the same size???
Cheers Si
Swamped
Re: Suzuki Samurai boss kit!!
Post by Swamped »
Easier to find one second hand cheap as they can be pretty expensive. Try looking for suzuki sierra as well as samurai. 413s may be the same also??
Otherwise I've seen em for around 80 bucks.
lilpigzuk
Tiger Balm
Post by lilpigzuk »
Sj410, 413, samurai, swift, vitara (early ones anyway) all have the same spline, ie you can interchange the steerings wheels, I have run swift gti wheels on my past 410/413s and used a 410 to move a vitara round i had. Try expanding your search to incluce swift and vitara/escudo.
UBZ
Post by UBZ »
ive got a vitara steering wheel in my zuk. looks stock as , horn works and it is quite bit smaller in diameter than the 413 wheel and has a nicer feel.
main problem i seen using a boss kit was that it was going to push the steering wheel out another 50mm into the cab , where space is tight all ready.
bobrocket
Post by bobrocket »
If you already have a steering wheel you want to fit.......I saw this guy on trade me when I was looking for the safari, a bit on the expensive side but just another option.
http://www.trademe.co.nz/Trade-Me-Motor ... 101188.htm
lneil
Post by lneil »
I've bought a couple of new ones at around $80 and found a second-hand on Trademe.
Aftermarket wheels usually don't sit much higher in the Vitaras as the mount face is not recessed anywhere near as deep as the mounting surface on a factory 'zuk wheel.
Lebmob
Post by Lebmob »
Thanks heaps you guys, it seems that i need to keep looking on old trademe for a cheap second hand....
Appreciate the feedback
Return to “Tool Shed”
