Selling 1994 Mitsubishi Pajero 3000 V6
Selling or wanted vehicles.
pjb
Post by pjb »
http://www.trademe.co.nz/Trade-Me-Motor ... 002072.htm
Set up for great off-road capability:
Retrofitted with factory rear air diff locker (similar to ARB design). Awesome for uneven terrain.
50mm suspension lift with increased front suspension travel (ball joint flip + spacer).
40mm body lift to fit larger tyres.
5 x 265x75R15 Yokohama Geolander all terrain tyres on factory rims, 8-10 mm tread.
Also available 4 x 33x10.5R15 BFGoodrich mud terrain tyres on factory rims 13-14 mm tread (pictured).
5.29:1 diff ratios (adjusts for 33" tyres), fantastic torque and engine braking.
All modifications fully certified.
Mitsubishi super-select 4wd system: 2 high, 4 high (AWD), 4 low (centre diff lock).
Factory adjustable shocks: soft, medium, hard.
Factory hydraulic ride height control.
Electric, heated mirrors
Sunroof
Tinted windows
Bull bars
High / low beam spot lights
CD player
Very civilised highway machine, works amazingly well off-road. Great for towing. So much cheaper that a toyota hilux or landcruiser prado, or a nissan terrano, patrol or safari for the amount of gear you are getting. Can't beat this value.
Heads, timing belt, water-pump done recently. Lots of other bits regularly maintained.
Have bought another pajero with winch etc, so this one has to go.
94 Pajero SWB, 3.5 V6
