if anyone has one knocking around let me know need to get my beast back on the road
SUZUKI ESCUDO G16A CYLINDER HEAD WANTED
Hey im after a good cylinder head for my suzuki escudo as mine is cracked and mixes oil with water
been told its very common
im in the wellington area cheers guys.
Re: SUZUKI ESCUDO G16A CYLINDER HEAD WANTED
There's an 91 escudo 5 door at pick-a-part in wingate, someone's been at the engine (I think the rocker cover's off it, not sure) but the head was on it when I was there, I think it's a 16 valve though, might be worth a ring?
Pretty sure its a 16valve injected one, I got the fuel tank out of it
Didn't barbie drive a jeep??
sweet as cheers guys i might have a scoot over at the weekend for a look
Just been an had a nosey, Its a g16a 16 valve engine
- zephyrheaven
its not always a crack, sometimes the frost plugs under the cam let go giving an oil/water mix - pressure test cooling system with rocker cover off should show if thats the case
