2.4 hilux cutting out
Posted: Thu May 06, 2010 6:15 pm
by GotFlex
a mate got a 87 hilux with a 2.4 diesel in it and it cuts out after a little while driving. like looses fuel, cxhanged the primer pump and the filter but its still doing it. any help guys??
cheers.
Re: 2.4 hilux cutting out
Posted: Thu May 06, 2010 7:58 pm
by niblik
there may be a small crack somewhere in the flexi fuel line somewhere...?
i know my diesel in the dyna was doin that when it had the above...
Posted: Thu May 06, 2010 8:01 pm
by GotFlex
so i should look for a small leak? or would that be sucking air into the injector pump?
Posted: Thu May 06, 2010 8:23 pm
by niblik
i had a bit of both dependin on acceleration etc..
look for a small crack allowin air to leak in under load.. ie when engine rev's..?
sorry, i only found mine by lookin about.. it might bleed out when it stops? luckily mine bled a little diesel when stopped..
good luck!
Posted: Thu May 06, 2010 8:29 pm
by GotFlex
cool, thanks for the tip much appreciated
Posted: Thu May 06, 2010 9:24 pm
by tweake
fit a bit of clear fuel line on the pump return and watch for bubbles. if any put it on the inlet side and see if its the pump itself.
also don't forget fuel solenoid itself or connections.
Posted: Thu May 06, 2010 9:49 pm
by GotFlex
Oh yea thats a good idea, there appears to be a diesel leak at the diesel pump. not heaps but could that be the cause
Posted: Fri May 07, 2010 10:40 am
by suzolla
Hi,
Have you checked the in tank filter that is on the end of the suction pipe, try blowing some air down the fuel line bck into the tank and see if that improves the situation, if it does take out hte filter and give it a proper clean. Had this prblem when I was running veg oil.
Tim
Posted: Fri May 07, 2010 7:33 pm
by tweake
GotFlex wrote:Oh yea thats a good idea, there appears to be a diesel leak at the diesel pump. not heaps but could that be the cause
if its leaking fuel out the pump then it will be sucking air in for sure. usually they will suck air in before they leak fuel out. once you get a big enough air bubble it will starve the motor for a bit, then come right till the bubble builds up again.
