Hello
Hello
Hello,
I'm new to this forum and thought I may as well say "hello".
I'm new to 4x4's and have recently purchased a 1998 Grand Vitara - it's the newer body shape (1998 - 2002?). 5spd manual,2ltr,white and stock standard besides tints.'
I went over to Red Rocks today for my first off road outing ever and really enjoyed it. I did not go over devils gate as I was not sure if my Grand Vitara would cut it re ground clearance, traction as I have the stock standard tyres and me being a novice!
Please let me know if it's worth a shot next time I'm out there.....
The Grand Vitara is my daily driver so it's a 80/20 rule when it comes to off roading for me. Looking to do a few basic mods to make my ride my enjoyable. i.e A/T Tyres, recovery gear including the hooks and possibly a small lift and snorkel if anyone can confirm if I will require these (lift and/or snorkel).
Not really keen on a lift as I would like to ensure the Grand Vitara maintains driveability and comfort on road.
If anyone can provide some advice on their lift experience and if it's required for a part time "Shiny" it would be much appreciated.
Looking to do a driver traning course if anyone knows of one coming up - I assume these are worth it as I'm alway reading or hearing about people getting stuck in the bush or the Hutt River!
Blair
Blair
- skid
- Tyre Man
Re: Hello
ya best bet is to join up with http://www.ccvc.org.nz/
they are a large club that cater for folks new to wheeling
they regularly have driver training etc etc
you could tag along on our trips, but sometimes theres not much training involved, its just a case of try and keep up
and also without decent tyres ya fairly limited as to locations to go and then we get into the dents and scratches that may occur and then............
oh well ya see where I'm headed
not scaring ya off, just making ya aware as others have arrived on shiny trips only to get a few bush scratches and complain
best bet is to come on a red rocks trip if ya see one organised and take it from, coz theres no damage to be done around there
Re: Hello
Come along to Rallywoods next weekend and say Hi, Rallywoods tracks arent shiny friendly so park up at the hut and jump in a seat.
check out kiwi4x4.org.nz as well.
Have a chat to robo re tyres and stinky re hooks. I ran Wranglers on mine and were good on the road, found the factory AT2's very skittish in the wet.
Re: Hello
coxsy wrote:lifting alittle bit will not hurt road manners,
X2. Mine runs an old man emu shock and spring lift. No handling prob
I run 225/75/16 with the above and only have slight rubbing on the right rear. These are about 30" whereas standard are about 27".I run them on lwb rims. Mine has suffered body damage. Currently it doesn't have 4wd. There's some problem with the front diff that I haven't bothered looking at since getting my hilux. If you're careful you should go over devils gate ok
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
- skid
- Tyre Man
Re: Hello
Devils Gate will be a cinch
seen Ford Territory's around further and a Mercedes AMG500 thingy as well
plus if stock standard 3 door vitaras can get over on weeny tyres then you should be fine
Re: Hello
As for the snorkel, I don't know where the intake is on the suzukis, but expect to get wet carpet before a snorkel is required.
As far as I can see, the main advantage is keeping the engine running if you go swimming deeper than planned, in which case wet carpet is the least of your worries.
94 Pajero SWB, 3.5 V6
Re: Hello
from memory there are no aftermarket snorkels for the grand Vit, you would have to custom make one, so best to do an OME suspension lift and fit bigger AT Tahs so your higher out of the water
Re: Hello
badnuz wrote:from memory there are no aftermarket snorkels for the grand Vit, you would have to custom make one, so best to do an OME suspension lift and fit bigger AT Tahs so your higher out of the water
Snorkels are available, I've got an Airflow one on mine. This doesn't fit models with ABS. If you have ABS, the only off shelf option I know of is http://outdoorauto4x4.com/p/602852/gran ... 98-05.html
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
Re: Hello
Thank you for all the input so far......
My GV does not have ABS - from what I have read this is a good thing when it comes to off-road.
From the advice so far and reading this forum it sounds like I will need some/if not all of the following
* Good set of A/T's - 30's max - I assume these will de-power the mighty 2ltr GV!
* Possible lift kit - say 1" - 2" max - but sounds like the 30's will fit without lift
* Snorkel - in all honesty prob don't need a snorkel as I'm a shiny and that's even pushing it! - but, as I have read it's not worth the risk of getting water in the engine system at all!
* Snatch rope
* Recovery hooks
* Shackles
The other thing I am concerned about is the under body/drivetrain. Does this generally have some kind of protection from factory - remembering I'm a shiny and won't be taking on anything too extreme. I beleive the GV's also may have factory breathers installed - which I supose is a good thing if I do happen to get a wee bit wet....
Slowly learning - I knew nothing about 4x4's 2 weeks ago - so far I have purchased one and have learnt a little - but have a lot more to learn re off road driving and equipment wise yet!
Might try Red Rocks again this weekend on my Street Tyres - but, will be staying well clear of the sand as I only have a spade and man power at present!
* Snatch rope
* Recovery hooks
* Shackles
- skid
- Tyre Man
Re: Hello
BMC wrote:Might try Red Rocks again this weekend on my Street Tyres - but, will be staying well clear of the sand as I only have a spade and man power at present!
hey dude, was that you in the white GV with roof racks ( I think) about 10am on saturday
stopped and talking to our resident whale (wgtn-newbie) briefly and then we all overtook you 2 mins later
you should of said gidday, you could of driven over Devils Gate then hopped in with me or a number of others to see the rest of the coast
Re: Hello
skid wrote:BMC wrote:Might try Red Rocks again this weekend on my Street Tyres - but, will be staying well clear of the sand as I only have a spade and man power at present!
Dam - that was me Skid in my shiny! - I made it to Devils gate and found I had a nice screw in my tyre - so turned around and went home - would have loved to have seen the coast- never been around before!
