Knock, Knock, who's there?
Posted: Sun May 09, 2010 8:41 pm
by marmel
Noticed over the last week there is a bit of a knocking noise coming from the front end, mostly when turning.
I've had the vehicle for a couple of months (LWB GQ) and since then have put 33's on and done a 40mm bodylift.
I guess anything that was half worn would have been put under a bit more pressure when the bigger rubber was fitted and is now failing.
Could it be the CV's? I've had a look underneath and there is nothing that is obviously loose.
Re: Knock, Knock, who's there?
Posted: Sun May 09, 2010 8:43 pm
by skid
knocking in 4wd or 2wd or both ??
Posted: Sun May 09, 2010 8:54 pm
by marmel
2wd, haven't tried it in 4wd. It's most noticable at slower speeds.
Posted: Sun May 09, 2010 9:09 pm
by DaveM
Does it do it while staionary and turning lock to lock? Old Safari did this, and Cruiser does it now.
If it does it while staionary, you can possibly find it by having someone turn the wheel while you check it out underneath.
Mine is coming from the tie rod
Posted: Sun May 09, 2010 9:23 pm
by juz
Doubt youll hear any noise from CVs unless in 4wd, Mine knocks when going around a corner at slow speed, suspect its the front trailing arm bushes.can feel it through the floor, somebody else posted this problem a wee while back.Ended up being loose body mount bolts. Given the bolts a tweak after doing the body lift and driving it for a while?
Posted: Sun May 09, 2010 10:12 pm
by marmel
I will have a look at the body mount bolts but as they are all nylock I can't imagine they have come loose after 3 weeks.
I suspect it is probably one or more of the bushes, might have to get it up on a hoist and have a decent look.
Posted: Sun May 09, 2010 10:16 pm
by muskie
seems pretty common after a body lift, my last three gq's have done it. it can be cured, usually feels like its under you feet.
Posted: Sun May 09, 2010 10:19 pm
by marmel
Yeah that's just what it feels like, uner the feet area.
What was it with your GQ's?
Posted: Sun May 09, 2010 10:41 pm
by juz
If it is your trailing arm bushes Id buy from auz like the ones below, $120aus a set of 4 were as 4wdbits are $64.99ech
http://cgi.ebay.com.au/Trailing-Arm-Uppr-Lwr-Bush-kit-Patrol-GQ-GU-Maverick-/230436935837?cmd=ViewItem&pt=AU_Car_Parts_Accessories&hash=item35a71c989d
just an idea.What ill probably end up doing..
Posted: Sun May 09, 2010 11:03 pm
by mroffroader
It is most probably the chassis end trailing arm bushes. BUY GENUINE NISSAN bushes they are the best. If the problem still occurs try putting another washer on before the big nut :wink:
Posted: Mon May 10, 2010 7:22 am
by DaveM
I've only had Radius arms give that problem, never trailing arms, especially if it's coming from the front end.
Body mounts are def. worth starting with though
Posted: Mon May 10, 2010 10:44 am
by darinz
I'm guessing you notice it a lot more when the road is wet?
Body mount rubbers are stuffed so tightening the bolts won't do anything. Replacing the rubber mounts is the solution but I'm guessing once you see the price and work out that you need 8 (or 10 if LWB) then you'll put up with the knock.
There are about 3 or 4 different types of bodymounts on GQ. They have a thin rubber piece that is what stops them moving about and when that wears out you end up with metal on metal and they move causing the knocking noise. Eventually the knock will stop and that is when the steel part of the body mount has completely worn away. Then it is just the rubber around the bolt holding it in place. At this stage the flex will cause the body to tear around the body mount.
I thought hard about getting a thin rubber (from Para rubber) eg about 1mm thick, to fit in to stop the mount slipping about. Didn't do it as sold the truck and the new one is solid mounted with no rubber mounts at all. (don't do that unless doing complete truck modification as it will tear the truck apart!)
Also radius bushes are likely tired. Chassis end flogs out pretty quick once the truck is lifted. The axle end ones have a habit of ripping the crush tube out of the rubber. This is good for offroad peformance but mean they knock when on road.
Posted: Mon May 10, 2010 6:58 pm
by muskie
marmel wrote:Yeah that's just what it feels like, uner the feet area.
darin beat me to it, and he explained it better. i am still looking for a solution other than buying new ones.
Posted: Mon May 10, 2010 9:04 pm
by Shane
I released the body mount bolt, lift the body enough to squirt some urathane(spell,black window screen glue)then tighten bolt up..hasnt knock since...you didnt here it from me though,someone has logged in under my name :shock:
Mr X
Posted: Mon May 10, 2010 9:11 pm
by u13turbo
my parents mistral makes a bang/click noise at full lock over sort of bumpy ground, same as my bluebird, maybe just a nissan thing?
Posted: Mon May 10, 2010 9:16 pm
by muskie
u13turbo wrote:my parents mistral makes a bang/click noise at full lock over sort of bumpy ground, same as my bluebird, maybe just a nissan thing?
no, thats a cv joint about to give up :shock:
Posted: Mon May 10, 2010 9:18 pm
by u13turbo
really? its done it ever since 80,000km when they bought it, done 200,000kms now still doing same thing...
Posted: Mon May 10, 2010 9:57 pm
by marmel
IFS vehicles have steering stops which can make the noise you are describing at full lock. Easy to fix though if you have a look in behind the front wheels you will see the stops, just stick a heap of grease on them.
I have had 3 Terrano's and a Surf, all of them made this noise at full lock.
Posted: Sun May 16, 2010 10:42 am
by muskie
hey darin, i know you would have put alot of thought into doing the rigid mounting of the body, if you know all the problems associated with doing this cracking body/breaking screens etc can i ask why and what you hope to achieve.. is it common practice in the comp scene or ''development'' on the new truck?
