IFS front diffs - Whats the best
Rotazuk
Post by Rotazuk »
Hello
I raised this a few years ago but shelved it etc but now the trial rules have changed and you can replace an independand diff in a class , this is a good option for a vitara . There rear diffs are not too bad , but the front is weak etc .
So whats the best ifs diffs out there . what there ratio and are they low or high pinion ?
The Pajero got mentioned last time , gen 2 etc . High pinion , can't remember the ratio's , but they do not have a removable head . While not a requirement would be nice .
What else is out there ?
Chris
NJV6
Re: IFS front diffs - Whats the best
Post by NJV6 »
Paj ratios are
4.625,
4.636,
4.875 (4.88)
4.900
5.285 (5.29)
The 5.29 is not available in the larger diff but even the 7.25 inch is alot meatier than an 8 inch Toyo one.
All HP.
Heath
Post by Heath »
found an article online that used a surf diff and surf rear some time back. looked interesting.
Make sure you do a build diary for this puppy...
Return to “Tool Shed”
