92 terrano need advice on servicing
Posted: Sun May 16, 2010 2:13 pm
by Rustaroo
Hi
I just purchased a 92 terrano 2.7turbo diesel auto and would like some general advice on how oftern to do oil and air filter changers and any other advice that may be helpful. thanks
Re: 92 terrano need advice on servicing
Posted: Sun May 16, 2010 10:54 pm
by kiwipete
I do my engine oil and filter every 5000k, fuel filter every 10000k and air cleaner when it's dirty. I have a washable air cleaner.
Transmission I get done at an auto shop as they service it too, Hi/Lo transmission and diffs I check twice a year.
Easiest way to remove the oil filter is to go through the wheel well, jack up and remove the passenger wheel, break the seal on the filter then place 2 supermarket bags over the filter. Unscrew it and let it fall into the bags, twist the end, lay horizontally and remove. Place a large rag in there to collect any drips. This is the best way I have found to prevent oil collecting and dripping everywhere.
Remember to place a smear of oil on the rubber seal of the new filter when replacing it.
Posted: Mon May 17, 2010 6:23 am
by Rustaroo
Thanks for the advice, much appreciated. what type of air filter do you recomend?
Posted: Mon May 17, 2010 6:48 am
by kiwipete
It's a personal preference really but I use a washable filter "unifilter" is the brand. I have kept my paper filter as a spare all the same.
When draining the sump, be prepared for a major gush as the oil travels quite a distance as the bung comes out.
Posted: Mon May 17, 2010 7:12 pm
by Rustaroo
thanks very much you've been a great help
Posted: Mon May 17, 2010 8:14 pm
by aroma
mine used 6 ltrs of engine oil ,I used a cut down 20 ltr drum to catch it in
Posted: Mon May 17, 2010 9:36 pm
by toominator
plastic bag idea = full of win
wish I'd thought of that, I made a bit of a mess last time (first time)
what sort of oil do you guys use? im using castrol gtx professional, just get it in a 20L as opposed to a 4L and it becomes 'pro'
I'd be interested to know if anyone uses tection hd as it has more cleaning additives etc in it. I might change oils when I've used this container up
Posted: Mon May 17, 2010 10:54 pm
by kiwipete
I use Valvoline as it is what the dealer used when the truck came into the country.
