Jammed up gearbox in my series LR
Posted: Sun May 16, 2010 3:54 pm
by Nizsafari
Hey all.
One minute i had gears now nothing, the leaver wont select anything for some reason. Ive tried gentle persuasion and harsh words but nothing apart from a slightly bent gear lever now... is this a common fault??
Re: Jammed up gearbox in my series LR
Posted: Sun May 16, 2010 3:59 pm
by Jerry
Have you tried a larger hammer on teh leaver, does the 4wd leaver work as well?
Posted: Sun May 16, 2010 4:07 pm
by Nizsafari
Jerry wrote:Have you tried a larger hammer on teh leaver, does the 4wd leaver work as well?
The transfer case levers work fine.. just the gear lever, it moves freely in neutral, just wont select any of the gears
Posted: Sun May 16, 2010 4:10 pm
by Lynx
With motor running? or Off?
Cheers Daniel
Posted: Sun May 16, 2010 4:11 pm
by Jerry
fluid clutch? is there a slave cly leak?, does it need a bleed?, is there any adjustment on gearbox thingy?
Posted: Sun May 16, 2010 4:14 pm
by turoa
Take the shifter off and see if you can move the shift rods manually
Posted: Sun May 16, 2010 9:03 pm
by Nizsafari
Lynx wrote:With motor running? or Off?
Cheers Daniel
Both... wont do it on or off
Posted: Sun May 16, 2010 9:07 pm
by Nizsafari
Jerry wrote:fluid clutch? is there a slave cly leak?, does it need a bleed?, is there any adjustment on gearbox thingy?
One min it was good, next it wasnt....pass, pass, do you need to bleed??
, pass..
Posted: Sun May 16, 2010 9:26 pm
by Nizsafari
turoa wrote:Take the shifter off and see if you can move the shift rods manually
Does the shifter pop out oris it a pull the sucker to buts kinda job??
Posted: Sun May 16, 2010 10:14 pm
by turoa
Nizsafari wrote:turoa wrote:Take the shifter off and see if you can move the shift rods manually
Na its easy as. Its like 4 bolts and the shifter comes off. The shift rods are external so you can see em. Then just play around with them and see if they move.
Posted: Sun May 16, 2010 10:17 pm
by Nizsafari
turoa wrote:Nizsafari wrote:turoa wrote:Take the shifter off and see if you can move the shift rods manually
Sweet, Cheers Tu's.. I'll have a looksee tomorrow....
b.t.w.. made up a sweet throttle setup..apart form fixing a couple of vacuum hoses, the motor runs sweet
Posted: Mon May 17, 2010 9:29 am
by Nizsafari
took the shifter off... the rods were quite stiff, gave them a light tap, put the shifter back on and all good!!, gave the rods a light grease...sweet...
Cheers Tu's
