g52 behind 2lt
Posted: Tue May 18, 2010 9:13 pm
by JONO250
looking at replacing the worn out w56 box in my ln60 surf with a rebuilt g52 that I got for free. the g52 that I got is out of a hilux, the transfer case looks different, do i need to run the w56 one? and will the w56 bellhousing bolt up to the g52??
Re: g52 behind 2lt
Posted: Tue May 18, 2010 9:23 pm
by Smurf
W56 has transfer lever out the top of transfer box
G52 has transfer lever out of gearbox, has internal linkages that go through to the transfer, which is why they look different, not interchangeable, as they also have different splines.
So the transfer case lever on a W56 is a few inches further back on a W56 box.
Bell housing will swap
Re: g52 behind 2lt
Posted: Wed May 19, 2010 7:22 am
by JONO250
So I could still run the g52 if i was to modify my floor a little to fit the g52 transfer lever??
Re: g52 behind 2lt
Posted: Wed May 19, 2010 8:03 am
by Smurf
JONO250 wrote:So I could still run the g52 if i was to modify my floor a little to fit the g52 transfer lever??
YEP.
ln60 would/should have had a G52 originally, I swapped out a G52 for a W56 in my yn60, just had to take 40-50mm out of the back of the hole in the trans tunnel. I filled in the front of the hole so I could fit the rubber boot and surround from the W56.
You just need to do the opposite I guess...
Re: g52 behind 2lt
Posted: Wed May 19, 2010 7:22 pm
by JONO250
sweet cheers for all your help. tag sais its a w56 and im assuming its still the original box in behind there. will i have to get a g52 gearbox mount or can I still run the w56 one. cheers for all your help, least I know that its not a straight bolt in job now!!
Re: g52 behind 2lt
Posted: Wed May 19, 2010 8:22 pm
by Smurf
JONO250 wrote:sweet cheers for all your help. tag sais its a w56 and im assuming its still the original box in behind there. will i have to get a g52 gearbox mount or can I still run the w56 one. cheers for all your help, least I know that its not a straight bolt in job now!!
gearbox mount is the same.
Re: g52 behind 2lt
Posted: Thu May 20, 2010 4:22 pm
by muddyhilux
hey mate,where abouts are you,i have a w56 box out back i need to get rid of and am then looking to aquire a g52,maybe a swap of some sort could be worked out?
Re: g52 behind 2lt
Posted: Thu May 20, 2010 9:50 pm
by JONO250
west auck. what condititon is the w56 in?
Re: g52 behind 2lt
Posted: Thu May 20, 2010 9:53 pm
by JONO250
oh yeah im also after a clutch line to suit 2lt diesel
Re: g52 behind 2lt
Posted: Fri May 21, 2010 11:26 am
by muddyhilux
not 100% sure,it came on the back of a motor thats now in my truck but ofcourse with sticks being different i took it off as i didnt want to mod interior,the old owner said it was all good and hed never had any troubles with it so i had full intensions of using it and expecting no problems,im just down in weymouth,if ya want you could come over and we could drop the oil out of it and inspect together so you kno what youd be getting,and yeh,i think ive got a clutch line somewhere aswell,let me know what ya think or txt me on 02102789016,chandler
Re: g52 behind 2lt
Posted: Sun May 23, 2010 6:52 pm
by JONO250
hmm after a bit of a think ,I may just run my g52 as I know its a good one, but cheers for the offer anyway.
Will a clutch kit off a toyota 4y fit a 2lt?
