she keeps stopping hurmph
aroma
Post by aroma »
got a slightly smokey f head have replace the
points,
coil,
dissy cap,
leads,
plugs and
condesor and latest the carb
runs ok but dies and wont start again :? have changed most of the above twice even have spare set of plugs!
as she sits turns over nicley,has spark,smells like fuel and when I checked them all compressions were within close and nearly even got me puzzeled
ideas??? cos i'm out of them :(
ta
Warren
niblik
Re: she keeps stopping hurmph
Post by niblik »
jebus your posts are hard to read sometimes warren!
Landy Rover
Post by Landy Rover »
Fuel pump?, restriction in fuel line or tank pick up? does it run a ballist resistor? bad conection in ignition circuit ie not enough current getting to coil??? A few places to look :)
S3 Rover truck cab, injected 186, Sals rear,Toyota P/steer, Safari disc brakes front, R/Rover D/brakes rear, 9500 winch,twin optima batts, roll bar, Disco seats, 33" JTs, scene lamps, onboard air, Front ARB locker.
ClassicCruiserSpares
Could be fuel pump not suppling enough fuel to to keep it running, does it have and inline filter somewere it could be blocked and not letting the fuel through quick enough.
aroma
Post by aroma »
thanks
classic crusier spares she has electric fuel pump and have replace all the fuel line (6mm)from tank to carb has filter just before the carb so will replace/bypass that.
landyrover how do you check for the power to the coil ? have rewired it all but will recheck
is the edit better on the post nibs? I do try a proof read to see if it make sense but some times have off days
have remembered haven't changed the rotor so will replace that too
so into the garage for me tomorrow nite
Heath
Post by Heath »
sticking float in the carb?
Stuck in up position so fuel cant get into bowl as fast as it drains out.
sibainmud
Post by sibainmud »
When I was 15, I learnt an internal combustion engine needs 3 things to keep it going; Fuel, Compression, and in the case of petrol, spark. I'm now a Marine engineer and I work on everything from 1 cylinder petrols and diesels to big block V8's and V16 Diesels. With problems like this the best tools are a timing light and a can of engine start. With the timing light you can see if there is "HT" from coil or dizzie. If it is a fuel problem a quick squirt of ether will let you know if it is or not. If after a squirt there is no firing then it is an electrical issue.
I'm a Diesel convert!
Hope this helps.
Cheers.
aroma
Post by aroma »
well had a play found 1 dodgy looking wire :oops: fixed
wouldn't start,lightly sprayed some horrible engine start in direction of carb and away she ran so am assuming its fuel
thanks guys
and back on with the old carb
need a webber,need a webber. chant to self
yeti
Bruiser
Post by yeti »
aroma wrote:well had a play found 1 dodgy looking wire :oops: fixed
thanks guys
i think its the way ya park it
v8 tj...luvs the gas......
lincooln
Post by lincooln »
^^^^^^ :lol:
Lubrication Specialist
Lubrication Engineers
aroma
Post by aroma »
that wasn't parked was still moving
.......................................................................... sideways :D :D
