Been spending some time under my cruiser and realised that the later model bodies (with petrol tank under floor instead of under drivers seat) have very limited space to weld in an Anti-tramp rod... bloody fuel tank gets in the way...
So I've read some threads and need some advice.
I'm thinking of using a tractor Top Link as my bar and setting up directly over the rear diff head (offset) and over the rear drive shaft (as this is the only direct access to a cross member) much like Wopass Mach 1 model:
The Tractor link has ball joints at each end which I reckon will not limit flex in anyway but my concerns are:
1. Do I have to go with a triangulated set up? &
2. Is it absolutely necessary to have the Anti tramp bar in the centre of the diff??? If so why?
I see that Wopass changed to this setup (which I cant do due to the fuel tank being in the way) which Richard has commented on (and I need to check that my below assumption is correct)
http://i248.photobucket.com/albums/gg193/wopassx/DSC05297Large.jpg
Bulletproof wrote:...The big difference is that a cruiser has an off set diff so what Wopass has done is good because the anti tramp is in the middle of the diff.
The diff on a hilux is in the middle so therefore the rotation point can only be on top of the diff to make it work right so that both springs move up and down wihout stress...
I think the ball joints at each end of a tractor link should sort this out right?
I really can't place it in the centre of the diff - there is just no room there.
Advice appreciated (sorry no photo of gas tank in the way
