Transfer question?
Posted: Sat May 29, 2010 9:28 pm
by suzookyman
Hi, can anyone tell me if a transfer case out of a 1996 samurai (coily) will fit a 1985 sj413?.
cheers Al
Re: Transfer question?
Posted: Sat May 29, 2010 9:52 pm
by Rotazuk
The flanges will be different ( possibly swapped over ) and it will not have the handbrake on the back ( again may be able to be swapped over ) .
If its still a gear case then it should be able to be installed . I am just not sure when they went to the chain t/case . Thought it was the jimny but it may be the coily's , more I think about it I am sure it was the coilys . The bits may still swap but I have never seen a coily case so not sure .
Sounds like an expensive way to get a t/case for a 413 .Would think a 413 case would be easier to find and cheaper .
Chris
Posted: Sat May 29, 2010 10:06 pm
by suzookyman
yeah, mates 413 has a stuffed one and i have this one out of a coily lying around and thought i could save him some bucks
Al
Posted: Sun May 30, 2010 1:19 am
by UBZ
From memory coily cases are chian drive, weaker, slight different ratio, flanges and mounts. Like every thing else coily, not compatible with anything else.
I'd be looking for a 410 case , cheap but still have to change flanges, but will help with turning those bigger than stock tyres I'm sure it's running.
