dazza85 wrote:When I changed mine over I also replaced the inlet manifold as the inter-cooler does not line up with the non IC manifold.
Here I have thought of turning the non intercooler outlet 1/3 on its triangular flange. This will allow me to use 2x90deg silicone elbows with a small section of tubing to join the ends together.
The small nipple on the side of the IC is the the connection to the boost as said above that is connected to a nipple on the non I/C manifold I found that the motor runs rough without this connected.
Can you provide further info where this other nipple on the non intercooler manifold is please?
I got an electric fan fan from the local pick-a-part. I just went around the cars till I found a front mounted one that would fit. ( I will try and find a photo )
Photo would be good please, no pick-a-part places here in Chch.
Also did you get the other half of the 3 mounting brackets ?
Yes there seems to be a lot of other brackets and bolts in a plastic bag with it all. Is there a reason you asked?
Just re-reading your post here, this is going on a Terrano, is yours the same?
