body lift blocks
mightyhilux4x4
body lift blocks
Post by mightyhilux4x4 »
:| hi again guys im ready to lift the body on the mighty hilux im only going 2 inch but need to know if i need tube(crush) inserts in the body blocks(nolathane or similar) .is this a legal requirement to have or just a personal choise.. :?: :mrgreen:
Lynx
Re: body lift blocks
Post by Lynx »
Yes you need them
Cheers Daniel
EDIT, so it make more sense.
In my opinion, i would put them in, that way you decrease the possibility of the bolts coming loose.
Cheers Daniel
tallsam66
Post by tallsam66 »
If you use UHMWPE plastic blocks you wont need any crush tubes...that stuff is incredibly strong & will never crush.
There is also no legal requirement with regard to materials for any bodylifting in any doc, neither for getting a warrant or a cert.Only thing close to a mention is very general in that material for anything must be suitable for the purpose.
92 safari 17
Post by 92 safari 17 »
Ive got 2 inch body lift in a gq wagon, no crush tubes, blocks made from polyurethane "im pritty sure" my blocks arnt made to have crush tube, and i got it certed fine.
skidtoy
Post by skidtoy »
you dont need crush tube lift blocks,just need high tensile bolts and you'll be fine.
