Nissan terrano body lift advice needed
harryzanden
- Stropper
This is a probably very newbie question but ive looked through most of the nissan posts and havent found anything that really answers my question. I have suspension lifted my terrano 2" with springs and wound up torsions (4 X rancho rsv5000s are on the way) and i want to body lift it 2" in the hope of getting 33s under it. so my question is this what will i need to do to lift it? i really want to know about what has to be done after ive lifted it like extending brake hoses etc etc. any/ all pictures would really help. Also with the all up 4" lift will 33s fit or will i need to do some chopping. Thanks for your help!!
Re: Nissan terrano body lift advice needed
Hello and welcome to the forums harryzanden.
Where are you from?
Here is a couple of "searches" I have done for you.
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=18&t=9717&hilit=+body+lift
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=18&t=20561&start=0
There are a lot of other topics on here that will help you out, but you will need to search for them.
Feel free to fire away any questions you have.
BTW, you will need to do some trimming, rear of front guards and front/rear of rear guards.
Where are you from?
Ph 0212078472
Ph 0212078472
General rule of thumb is:
3"body lift + 3" suspenion lift= 33" tires. Otherwise you'll have to cut as kiwipete mentions and I had to do also. You'll really need to beef up the front suspension though.
Al
Al
2" lift and shocks = 33's.... dont bye a lift kit ither ####### rip off....
50$ for blocks 20$ for bolts.... save ur self lots of $.
look around woth it ....
hi have a look on npora (google it) it is a yankee site dedicated to terranos but has a lot of info if you know where to look. found the site very handy for when I was modding my terrano
hillz wrote:2" lift and shocks = 33's
Not without trimming guards!
Ph 0212078472
Ph 0212078472
i olny cut like a cemtermeter off frount of frount grd. and used a hammer were the seam is at back of frount gard.
lol if that makes sence.... ah well
hillz wrote:i olny cut like a cemtermeter off frount of frount grd. and used a hammer were the seam is at back of frount gard.
I did not need to touch the front of my front guards, but I will need to trim the rear guards, front and rear as I only have 3mm clearance!
Ph 0212078472
Ph 0212078472
