Kzj78 100mm lift springs, wat shocks???
pradon35s
Post by pradon35s »
I have chamberlins 100mm lift springs, I am looking at getting new shockys but having no luck finding any biggest I can find is 50mm lift in the Raw range..
Anyone know where to get any??
I'm located in Christchurch
Thanks
rokhound
Re: Kzj78 100mm lift springs, wat shocks???
Post by rokhound »
Go and talk to Tim or Glen at Autolign in Wordsworth Street. If they don't have what you want, they will probably steer you in the right direction.
I would have thought Mark (Chamberlain)could help you out with shocks as well.
pradon35s
Post by pradon35s »
It had the springs in it when I got it with rancho adjustables but shocks are buggered n don't think il get ranchos I tried autolign said biggest they could do was raw 50mm lift.. Il try chamberlins cheers
rokhound
Post by rokhound »
You are obviously asking for 100mm lift over std Prado units.
Work out what the actual size (length) is that you need and then go looking through the catalogs. As long as you tell them what ends you have, and the full open, and closed lengths you want, someone should be able to help you out.
flexy
Post by flexy »
just get sum big 1s adam lol na il sort ya out dont worry
