What is it?
lincooln
What is it?
Post by lincooln »
Hi all, I got a replacement engine for my Mazda 626 and found that the replacement was just too different to work with out changing a lot of things.
I also now believe that it was a turbo, 12 valve fuel injected model not a carb model as i was told.
This came off it and I was wondering what it was?
To me it seems like it is a oil feed and return. It just went where the oil filter went then the oil filter went on afterwards. any idea's?
Lincoln
Lubrication Specialist
Lubrication Engineers
Pedro
Re: What is it?
Post by Pedro »
lincooln wrote:Hi all, I got a replacement engine for my Mazda 626 and found that the replacement was just too different to work with out changing a lot of things.
Lincoln
looks like a oil cooler that used radiator water to cool the oil
Pedro
Nivapulledout
Re: What is it?
Post by Nivapulledout »
yep that is what it is I reckon, alot of euro engines have them as it also works in reverse on warm up and warms the oil quicker then keeps it close to coolant temp.
lincooln
Re: What is it?
Post by lincooln »
cool thanks. just out of curiosity would it work as an oil feed for a turbo or not?
Nivapulledout
Re: What is it?
no cause the jacket separates the coolant from the oil side so there is no pass through ( apart from heat)
lincooln
Re: What is it?
Post by lincooln »
ah right, I see.
