AIR injection system for rangies
I was just reading my workshop manual and stumbled across the belt driven air injection system. Does anyone have one of these fitted to there rig as it sounds like a simple supercharger sytem. Any views or advice on the subject please let me know as I'm thinking of fitting one to my 5ltr Leyand for more power.
Re: AIR injection system for rangies
Athalus78 wrote:....I'm thinking of fitting one to my 5ltr Leyand for more power.
The three position Lucas switch - Dim, Flicker and Off.http://home.off-road.com/~bodgerover/
Given the Rover reputation for destroying axles diffs and CV's with a piss weak 3.5 ltr V8 what plans do you have for upgrading the drivetrain to avoid the carnage the first time you sink your right boot?
At the moment the standard running gear is holding up well to the 5ltr so with almost 6ltrs some slight adjustments to my driving style and I should be fine.The axles can be easily swapped for a nice set of maxi-drive lockers which the rear already has and as to CV's going all you have to do is lay of the loud peddle when your at, or close to full lock when turnning.. All else fails I'll have to steal and army Unimog and get the axels from that.
So far just a diff and a CV...
There was not a lot left of either of them as they were well grenaded...
To be fair though my 4.4 looks good on paper but the reality is that I doubt it puts out a much more power than a 3.5 in good nick on account of the fact that its flogged...
My chief encourager CT has a 90 with a V8 and he has chewed his way through multiple diffs including ARB's which are significantly stronger than the rover ones. Hes destroyed a lot of axles and CV's and also managed to shag R&P sets with ease with his carburetted [but well maintained] 3.5 - of course its all after market strengthened gear NOW....
ooops better put me down for a front inner axles as well - forgot about that one
"Sorry guys but I've had no probs with the driveline"
Hope you were touching wood...
The bigger you make that engine the more you are going to have to avoid using it if you don't build your running gear stronger... and there is something very wrong with that.
