Short 45 rebuild
Fakey
Short 45 rebuild
Post by Fakey »
This is my new project, Its the one that muddy hilux was working on. It turned up on the truck yesterday. Battery was flat an clutch master cylinder is farked an works when it wants :lol: but its my 1st v8 powered vehicle an it sounds awesome :mrgreen:
As it arrived apart from the old 31s on the back for skids :lol:
An had to try doing a skid, bit too much grease on the pad but still good fun an sounded great :twisted:
http://s851.photobucket.com/albums/ab74 ... f865c1.mp4
Had a bit of a look around it yesterday an decided it needs quite a bit done:
-engine gaskets replaced
-5 speed g/box fitted
-Chassis swap- its fatigued cracked an been butchered an a few places
-Body sand blastd an repaired (rust an damage)
-Roll cage, bar work an hillbilly light bar removed an redone when full fj45 roof is fitted
-The power steering needs to be completely done
-The engine needs to be moved forward about 50mm as it sits against the firewall
-Rear mounted radiator removed an one in engine bay plumbed up properly
-Front Brake lines replaced
-Full rewire maybe dash cut out an unmolested one welded back in :lol:
-Front an rear diffs will be replaced by larger coil sprung disc brake units :twisted:
-Tube guards front for clearance an to cover the 36's :mrgreen:
Will add to this list when I think of more sh#t it needs :wink:
Didn't barbie drive a jeep??
Fakey
Re: Short 45 rebuild
Post by Fakey »
Made a bit of a start today,
cut off all the bar work removed the light bar,
cut out the passengers seat (it was welded in)
revoved the harnesses,
removed the radiator lines that ran under the seats to the rear radiator an plumbed up the front radiator.
Checked that the airlocker in the rear diff actually works, it does its just not plumbed up :mrgreen:
Cleaned out the years of sand an crap on the floor of the tub :lol:
Removed the winch an fairlead, winch isnt wired up an wont need it for a while.
Did some skids then put the 70's wheels on it an took it home :mrgreen:
Bars etc removed
haydgq
Post by haydgq »
Thats crazy dude :lol: , you just sold a mint 40 and now pretty mush need to start from scratch with this one. :shock: did you get the simex's with it.??
safaripete
Post by safaripete »
nice
i have an fj45 cab/roof here if you want it has all glass but has been cut along the roof to fit my old cage
why 5 speed
is the 4 speed broken or something
Fakey
Post by Fakey »
skid wrote:why 5 speed
might be after driving from seaview to wellington with no clutch :oops:
but just to make it better for driving on the motorway an ive got one sitting in my garage ready to go :wink:
whats a motorway
theres no motorways in the bush :mrgreen:
just curious, coz my ol 40 easily did the tonne with the 4 speed in it and was still accelerating
just trying to save ya some extra work :shock:
Fakey
Post by Fakey »
Wont be much more work. Ill need new d/shafts to suit the new diffs an the front ones yokes are so worn they would fall out if used in 4x4 :lol: An the engine is coming out as well so I can rework the mounts to move it forward at the same time as the tub is away getting blasted etc etc etc :lol:
nzhunter
Post by nzhunter »
hah looks awesome man! should be mean fun
off topic question, i can guess where u work, what branch are ya at tho? I work at branch 20 as a mechanic
our steam cleaner pad gets skid marks put all over it too haha :)
Fakey
Post by Fakey »
nzhunter wrote:hah looks awesome man! should be mean fun
Haha branch 60, dam steam cleaner pad gets too much grease on it to hold it still
MNC
Post by MNC »
Fakey wrote:Had a bit of a look around it yesterday an decided it needs quite a bit done:
:shock:
I was thinking about buying this truck before I got stuck into the bush truck - V8, Winch, locka, and tyres make a nice list of accessories... but after reading your to-do list I'm kinda glad its you taking on this project. :roll:
Once your done with it I'm sure it will be an awesome truck - sounds real nice :twisted: :mrgreen: Good stuff :mrgreen:
callum007
Post by callum007 »
got a pair of custom made snorkels to fit that.. a left and right pair. brand new. never used. pm me if interested
