Land Cruiser 70 Series motor
Posted: Tue Jun 15, 2010 2:53 pm
by Ginzu8
Hi all.. just want to know if i can get my hands on a 1991 land cruiser 70 series but have a dodgy 2.4L diesel engine. would it be a straight swap over if i am to find and put a 3L 1KZ-TE diesel motor in it.. will the engine mount etc fit directly or do i have to make some up??
Re: Land Cruiser 70 Series motor
Posted: Tue Jun 15, 2010 4:35 pm
by sig
1kz is a totally different engine.different mounts and normally different gearbox as well(i think from memory).Afew have done the conversion .Someone will pipe in soon with a better list of things that will need changing
Posted: Tue Jun 15, 2010 5:31 pm
by Ginzu8
cool thanks. or should i just look for another 2.4L diesel??
Posted: Tue Jun 15, 2010 9:13 pm
by nstacey
You could probably bolt in a 3L (2.8 Diesel) or 5L (3.0 Diesel) both come as naturally aspirated in Hilux or Hiaces.
Posted: Wed Jun 16, 2010 1:18 am
by Ginzu8
thats my question. i want to know if its a straight swap if i want to put a 3Litre diesel to replace a 2.4 diesel motor
Posted: Wed Jun 16, 2010 9:06 am
by pradon35s
The bellhousing and gbox on 1kz is different pretty sure so is the transfer or the diff ratios.. But not 100% sure, if I were u i'd chuck. 3l 2.8 n/a motor at it as ur gearbox will work but then if u miss boost bolt all the turbo gear off ur 2.4 onto it..
Just my 2c
Thanks Adam
Posted: Wed Jun 16, 2010 11:48 pm
by Ginzu8
Sweet thanks.. i guess i am better off looking for a 3L diesel motor land cruiser prado .
Posted: Fri Jun 18, 2010 4:02 pm
by NJV6
The 3L never came in the prado, just the 2Lt 2.4 and the 1KZ which is a 3 litre motor. The 3L is a different motor and was in Hilux/Surf/Hiace
Posted: Fri Jun 18, 2010 5:40 pm
by chrome
iv come across before, when some people refer to a 3L (2.8 Diesel) they assume it is the 3 LITRE engine 1kzt. it confused me a little at first until i got found out :oops:
Posted: Fri Jun 18, 2010 11:05 pm
by Ginzu8
A bit lost here now. I had the 1kz-TE engine in mind when i was talking about putting a 3L diesel in a land cruiser prado. or have i mixed up??
Posted: Fri Jun 18, 2010 11:26 pm
by NJV6
No, its written above.
A 3L motor is a 2.8 litre non turbo motor
a 2L motor is a 2.4 litre non turbo motor
a 2LT is a 2.4 litre turbo
a 5L motor is a 3.0 litre non turbo motor
a 1KZ is a 3 litre turbo, not a 3L or a 5L!!!! A totally new motor than the 3L, not even the same capacity, and the capacity is the only thing in common with a 5L and a 1KZ
3L is an engine code.
Posted: Sat Jun 19, 2010 12:30 am
by Ginzu8
Well my bad for being lazy . when i put 3L i wasnt referring as the engine code but more for 3Litre .hence when i first asked the question i put down the engine code as the 1kz-te engine is the one that i want to ask to replace the 2.4 diesel engine as there is a land cruiser prado 70 series body on trade me with a dodgy motor.
oh another note. there is a land cruiser prado with the 1kz-te 3litre turbo motor done 260000kms, auto. is there anything i should look for when i go look at the car? mechanical side of things that is.
Posted: Sat Jun 19, 2010 11:09 am
by Jerry
for the LJ/KZJ Cruisers the gearboxes should be the same, changing between 2.4 TD(2lt/2lte) and 3L TD (1kzte) may require different bellhousings and engine mounts, the running gear is the same.
All of the above motors will crack a head at some stage, the non turbo 2.8 could be an option, could look at a commy v6 or a 1uzfe conversion as well
Posted: Sun Jun 20, 2010 1:56 pm
by Lynx
Jerry wrote:
ASSUME All of the above motors will crack a head at some stage, the non turbo 2.8 could be an option, could look at a commy v6 or a 1uzfe conversion as well
