94 Scud trans rebuild
For all Suzuki related topics
Brad230
Post by Brad230 »
Has anyone got info/experience on rebuilding the man trans on Scud's? Are they easy to do? I have a 5 spd man behind the G16A engine in a TD01W series 94 Escudo. I thought I could get the bearings from SAECO and had a tip to try GBI or Gearboxes International for other parts like synchro's etc. I guess its easier to buy a second hand one and fit that, but I would like to rebuild mine (and I need the practice for various reasons). Any help and thoughts would be greatly appreciated...
Heath
Re: 94 Scud trans rebuild
Post by Heath »
get a second hand one, recon that and fit it. Then either sell your old one as a going one or recon it and sell it for a bit more. :mrgreen:
Saves having the vehicle out of action for ages should something happen and if you give up take it and the other bits to a pro to do. All while still driving yours around.
Brad230
Post by Brad230 »
Thanks Heath, that sounds like a good option...
Rotazuk
Post by Rotazuk »
If you want a vitara box I have a 5sp manual and t/case from a 91 vitara for sale . $200 .
In in akl .
Chris
Brad230
Post by Brad230 »
Sounds great Chris, I presume this one is a runner? Do you have a cell number I can reach you on?
Rotazuk
Post by Rotazuk »
Yep swapped a efi engine into my cousin's vitara with a low ratio tranfercase , so it was easier to swap the lot instead of splitig the engine and box at the time .
Give me pm to come and have a look at it .
Chris
Return to “Suzuki”
