Prado rear diff ?'s
Rotazuk
Prado rear diff ?'s
Post by Rotazuk »
Hi
What ratio's do the coil sprung solid front prado's come in . I know 4.3 :)
Also if someone has one on the shed floor can you measure from the radius arm mount to the edge of the diff flange on each side . All I am after is finding out how much the diff head is off set , ie if one side is 400 and the other is 100 the head is offset 300mm , so what you meassure from on radius mount does not really matter so long as its the same on both sides .
Otherwise I will wait untill I see one in a carpark somewhere :)
Chris
mudlva
Re: Prado rear diff ?'s
Post by mudlva »
hay chriss give Murrey a call thats the diffs that he is using
ring mob as l/l does not work no more
Rohan
chrome
Post by chrome »
bout 85mm and 410mm it was dark and i had no torch
from the radius mount to the start of the pumkin curve
DIRTY OLD HILUX
022 519 7700
kbushnz
Post by kbushnz »
Rotazuk wrote:What ratio's do the coil sprung solid front prado's come in . I know 4.3
The 4.3 is in the 1KZTE (3.0L) powered.
The 4.88 is in the 2LT (2.4L) ones.
Calvin
suzolla
Post by suzolla »
Hi,
I think you will find that
it is actually only 100mm offset from the centre. if the head was moved 100mm toward the centre the measurements each side would be 200mm even.
Tim
Rotazuk
Post by Rotazuk »
suzolla wrote:Hi,
Tim
What school did you go to ? I recomend you go back to it .
400 - 100 = 300
100 + 100 = 200
So how would that put the diff in the center , its still 50mm out . Either way I need the measurement as asked for :) and it looks like it is about 300mm , not enough :( .
Chris
suzolla
Post by suzolla »
Hi Chris,
Yes you are quite right, the theory was right but the answer was wrong :oops:
Must have been thinking about the 300 and not the 400.
So for the 85 and 410 situation the offset from the centre will be (410-85)/2 = 162.5.
Tim
lilpigzuk
Tiger Balm
Post by lilpigzuk »
Will stop in on way home from work. Measure away.....
Rotazuk
Post by Rotazuk »
suzolla wrote:Hi Chris,
Tim
Post was intended as a little humor , not a dig . After a coffee or two it seems a bit harsh .
If you turn up rex hope the prado is empty :)
Chris
suzolla
Post by suzolla »
No worries, wasn't taken as a dig, would rather be told I am wrong rather than possibly misleading others. Relpy was just to show how I worked it out, not to make a point
Tim
chrome
Post by chrome »
162 looks to be accurate... its easier to see in the daytime and not holding onto a beer helps too :mrgreen:
DIRTY OLD HILUX
022 519 7700
