you know the things im talking about that you put on a cooling system usually the radiator to see pressure etc ...
im after one pref in welly somewhere but yeh
has anyone got a leakdown tester ?
- its_that_guy2
Re: has anyone got a radiator pressure tester ?
hi there, a leak down tester is for checking the engine to see were your compression is going, you are looking for a radiator pressure tester. try that may have a little more luck. but most car workshop would have one and probably wouldn't charge to have a check for you.
pressy
pressy
