26th/27th June
Posted: Sat Jun 26, 2010 6:54 pm
by NJV6
Well, since the club trip was postponed I decided to do some gardening....
How does this relate to 4WDing, well I couldn't do it with the Escape (just went brrrrrrr - needs a lower gear!!!) even though it is a company car so had to get out the Paj, a bit of a pull, no go, lengthen the rope slightly, diff locks in, slew sideways until one front wheel hit concrete and out the bush popped!
So yea thats my 4WDing for the weekend!
Re: 26th/27th June
Posted: Sat Jun 26, 2010 7:12 pm
by tallsam66
Went to Jaycar & brought a new aerial base to replace the one i broke last weekend at Poulter River...will install it tomorrow.
Re: 26th/27th June
Posted: Sat Jun 26, 2010 7:20 pm
by meece4x4
Started getting the Mistress prepped and ready for the Mud Drags next weekend at the Rally of Whangarei http://www.rallywhangarei.co.nz/
Every year the Whangarei 4wd club gets to entertain the rally crowd with mud drags and grudge racing :mrgreen:
spent today adding in some more under surface protection and knocked up a radiator guard to hopefully catch some of the mud before it hits the fins ... I had trouble with overheating during similar mud baths in the past.
Dropping the Whale off on monday morning for a complete injector/pump rebuild, calibration and "tune" .... should give the whale a little more opmh :twisted: as my son wants to drive the mistress against Dads whale :lol: havnt got a sh*t show in catching the Mistress in a Safari but maybe experience over youth might triumph
Re: 26th/27th June
Posted: Sat Jun 26, 2010 7:25 pm
by dazza85
tallsam66 wrote:Went to Jaycar & brought a new aerial base to replace the one i broke last weekend at Poulter River...will install it tomorrow.
Put a spring on the bottom of the aerial ... it protects the base from all but a direct hit. My 2c
Re: 26th/27th June
Posted: Sat Jun 26, 2010 7:59 pm
by 92 safari 17
Helped a mate start building a winch bar, he had a 36x14.5R16.5 Super swamper at his workshop looked pritty good, i need a bit more lift to fit them in tho, there a weird sized rim that ya need for the tyres to
Re: 26th/27th June
Posted: Sat Jun 26, 2010 8:40 pm
by lexulance
:D Well got the winch fitted and wired up on the hilux, tried it out in the driveway, put the winch rope on the misses' s car at the end of the driveway, firmly applied the handbrake in her car and proceeded to pull the car up the driveway, works well :lol:
gona need to put a bigger battery in the lux though for a bit more reserve :wink:
Re: 26th/27th June
Posted: Sat Jun 26, 2010 9:07 pm
by wopass
added wiper squirters to the missile,then added a bunch of bungees to the harnesses for getting in and out in a hurry...seems to work ok so far :lol:
Re: 26th/27th June
Posted: Sat Jun 26, 2010 9:43 pm
by skid
don't piss around, buy an optima, you wont look back
Re: 26th/27th June
Posted: Sat Jun 26, 2010 9:52 pm
by coxsy
weld up sliders for a prado, modded the spare tyre rack to fit 33's and me simexs :D and the 40 has a prs radio now
Re: 26th/27th June
Posted: Sat Jun 26, 2010 10:17 pm
by lexulance
:?: Whats an optima, and how much is it to buy one, i take it as being some kind of flash battery, gel cell or similar
Re: 26th/27th June
Posted: Sat Jun 26, 2010 10:39 pm
by skid
best battery out there, voted best for many years
spiral sealed lead acid AGM etc etc
http://www.optimabatteries.com/home.php
probably set ya back anywhere from $500 upwards depending on choice
otherwise get the biggest battery you can fit in there, make sure the alternator is cranking some good numbers
www.supercharge.com.au
SKID
Re: 26th/27th June
Posted: Sat Jun 26, 2010 11:16 pm
by lilpigzuk
checked my tyre pressures, were showing 28psi, freaked out :shock: went to my nearest BP, got them back to 32 front 35 back. Thank god for this thread for reminding me.
Re: 26th/27th June
Posted: Sat Jun 26, 2010 11:18 pm
by wopass
lilpigzuk wrote:checked my tyre pressures, were showing 28psi, freaked out :shock: went to my nearest BP, got them back to 32 front 35 back. Thank god for this thread for reminding me.
did you get gas while you were there bro?? can you get some for me?? :mrgreen:
Re: 26th/27th June
Posted: Sat Jun 26, 2010 11:23 pm
by lilpigzuk
this is a achievements thread Mr Wopass.......... not the failure thread :lol:
Re: 26th/27th June
by rokhound
But being BP that will all leak back out :wink:
Re: 26th/27th June
Posted: Sat Jun 26, 2010 11:27 pm
by lilpigzuk
like the joke said, throw a wedding ring on it, it will stop putting out :lol:
Re: 26th/27th June
Posted: Sat Jun 26, 2010 11:52 pm
by wopass
yea it leaks out the zaust as a big fat carbon foot print :twisted:
Re: 26th/27th June
Posted: Sun Jun 27, 2010 11:58 am
by vvega
did more chassis welding
Re: 26th/27th June
Posted: Sun Jun 27, 2010 12:06 pm
by aroma
glue together centre consol, started on shovel holder on spare carrier,wired up pug for spotlight on rear of cab,painted under seat tool box,winch bracket and look at replacement carb now to make/buy adaptor plate,playing with mounting air compressor in cab
Re: 26th/27th June
Posted: Sun Jun 27, 2010 5:57 pm
by UBZ
Finished both rear quarter /corner bars for the surf and made a slider for the zuk .
Re: 26th/27th June
Posted: Sun Jun 27, 2010 8:00 pm
by wopass
i think all that rum has addled your brain function piggy :roll: but you are a G'ninger so maybe thats normal :lol:
Re: 26th/27th June
Posted: Sun Jun 27, 2010 8:51 pm
by lneil
Got the coolant flushed and replaced in the V6, then tackled the list of WOF items for the yellow 3-Dr.
For the first time ever a WOF inspector decided it needs a rear bumper and mudflaps! So I just screwed on the plastic outer shell until the WOF's obtained, having checked with the local VTNZ manager and gone through the fine-print in the WOF manual to confirm that it's not actually a requirement.
Changed out both front steering outer links (worn ball-joints), the right front lower control arm ball-joint and replaced both front control arms. The inspector noted that the bushes were stuffed, indicating how the front of the bushes had totally disintegrated. Upon removing them I see that there is no rubber flange on the front bush section!
Replaced the left h/light ((holed by a stone chip) and now there's just a small section to weld in the floor pan near the rear body mount and its all done. After which I will be changing the WOF issuing agency I use.
Re: 26th/27th June
Posted: Mon Jun 28, 2010 9:14 am
by surf_tomo
went to look at this...
http://www.trademe.co.nz/Trade-Me-Motor ... 095366.htm
owner seamed to know very little about it, only had it for a couple of months, wouldnt let me drive it, and closed the hood soon after I opened it. When I questioned why the radiator fluid was like milk he told me it must be anti freeze :lol:
Dont think Ill be making an offer
Re: 26th/27th June
Posted: Mon Jun 28, 2010 10:57 am
by pjb
Changed all four CV boots, stripped and rebuilt my aisin hubs (evidence of moisture), put a couple of coats of paint on my winch bar after its mods to fit my new winch, extended the rubber skirts in the wheel arches to try and reduce the mud-fest in the engine bay.
Next, fit the bar and winch, take it for a WOF /cringe
